Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer began leaking. what should i check for?
  • Anonymous May 15, 2009
    whirlpool washer began leaking. what should i"
Check the water pump. you will need to remove the cabinet to see. once you can get the cabinet off, it is usually easy to replace the pump.
Posted on May 10, 2009
It suddenly began leaking somewhere on the inside. This happened first when I was not around and not only did it leak from the bottom, the thing kept filling up and not stopping, resulting in a flood in...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022642100/0582/0153200?pathTaken=&prst=0&shdMod=11022642100
and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Jan 25, 2011 | Kenmore 22642 Top Load Washer
My ultimate care 2 washer is leaking water. It appears to be coming from somewhere around the pump. It leaks whenever there is water in the tub. it does not have to be running at all. I poured a partial...
this could be one of 2 thingsyour not on a level surface or the seal has gone south./well i lied here is another therory your out let is not on or has a leak ,set it up a little higher on some bricks and run a short cycle see where its seems to be comeing from.
Oct 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer Leaking
Opened the Washer and found there was a leak in the pump. Got an M-Seal and just put it on the leak. 45 mins later the machine was in action again.
It took time for me to figure out where the problem was, once you know exactly where it is you should be able to fix it.
Jan 30, 2010 | Whirlpool Washing Machines
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesn't drain just buzzes
Most likely you have a coin stuck in the drain pump. Mine did the same thing, and we removed the drain pump, then removed the coin and it began working again. Just be sure to check all pockets for coins as this is a big problem with the Cabrio washers.
Oct 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a top-load washer that began leaking at the front of the unit. The water is dripping from the front-center of the machine. It begins leaking immediately upon filling and will continue to leak for...
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the area for the motor and pump.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 23, 2009 | Kenmore Washing Machines
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Brand new whirlpool cabrio began leaking
Sounds like you may have a small hole or a failure in a seal somewhere, is there a filter on the drain you could check this is secure and free from debris, is it possible that the drain hose has been kinked during a spin and possibly leaked? if it only leaks when it drains it is defenatley somewhere in the drain system. I would use your Insurance on this one Top loaders can be difficult to work with as the space inside them is very limited.
Nov 21, 2008 | Washing Machines
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
