Question about Amana ASD2626HE Side by Side Refrigerator
The fridge is not making ice but instead water pours out
  • english01 May 11, 2009
    MNFisherman The model number is AMANA ASD2626HE SIDE BY SIDE
  • 11,896 Answers
If water is overfilling the icemaker, and you have an older style icemaker, you can adjust the fill switch on the icemaker.
Pop off the front cover of the icemaker and you will see an adjustment screw attatched to a lever. Adjust the screw so the lever goes toward the - symbol. This will shorten the amount of time the water valve turns on to fill the icemaker. If the lever is centered between the + and - symbols, turn it about 1 turn toward the -. If it is more toward the + side, adjust it to the center. It may take a few adjustments before you get it filling correctly.
If it is a newer style electronic icemaker there will not be any adjustment on it.
If you will post the model number I will try to look it up and see what kind of icemaker set-up you have.
water pressure is fine but is the icemaker getting the right amount of water? the biggest cause of hollow cubes is as you know is low water pressure. another thing is check that the i/m is level allowing water to go all teh way to the head of the I/m. If you can dip your fingers in teh very fron cube mold and verify that water is getting all teh way there.
The sensor for mold temperature is at teh fron housing so that is why its important for water to get there or else it will sense water actual freezer temp instead of water/ice temp.
Posted on May 10, 2009
SOURCE: water dispenser in fridge
Possible problems could a bad water valve (dual valve), bad micro switch which is activated by pressing the button for water to come out. On some models the bracket that holds the micro switch could be broken not allowing the button to activate.
Posted on Oct 05, 2007
  • 76 Answers
SOURCE: My ice and water dispenser is leaking
I am not an expert on refrigerators, but generally you hook a 1/4" (copper or plastic) line to a solenoid valve to the back of your refrigerator, which you then hooks up to a filter, which then ties into an existing compression fitting, or saddle tap on a cold water line (usually on the kitchen sink). Some refrigerators have a place for a filter to fit which runs to the cold water, and not an exposed rear solenoid.
Posted on Sep 27, 2008
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
  • 531 Answers
SOURCE: Maytag refrigerator ice maker, pouring water out where ice should
change ice maker or check defrost
Posted on Apr 06, 2009
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why doesn't our new icemaker in a whirlpool ed5 fridge work?
Make sure water line valve is turned on where it taps in to water line,and that ice shut off is down not up, check to see if water is in ice tray or if it is dry if no water or ice is present then water is not getting to it if water tap valve is open then water valve in ice maker is off or ice shut off arm is up instead of down. Try pouring warm water in ice tray see if that will get it started.
Jul 21, 2014 | U-Line Icemaker
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
My fridge sterted to pour water from water dispenser instead of filling the ice tray.
There are two possible problems here. Either the water valve is going bad on the machine, or even more possible the main controla board, located on the back of the machine and can't be located by the silver square plate the covers it. Unplug the machine and remove the plate and look for any signs of burns or major discloration. This board controls everything on the refridgerator. A good place to order parts from is www.repairclinic.com because of their awesome return policy.
Apr 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Bad tasting ice
disconnected your water line to your fridge and let it rum in to a bucket so you will have fresh water for your fridge but before plug it back to your fridge pour a example in to a cup and drink it to see how it theist like. if that don,t solve your problem, there is a way to get rid of bad rubber taste on the water , but is kind of hard to do first you need to take you refrigerator out side because is going to be messy find some kind of water pump and a bucket and some hose. disconnect the water line going out of the water valve to your ice make and rig your hose together whit that one. on the bucket pour a full bottle of Synthetic vinegar "yes the same stuff you put in your salt", make sure is synthetic not the natural kind using a pump flush your refrigerator whit the vinegar, you can add some water if you need if there is two water valves do the same on both. good luck.
Jun 12, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Amana ASD2626HE Side by Side Refrigerator Logo
158 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
