Question about HP All-in-One Printer
How do I switch from letters to numbers on the HP all in one printer? When I put in numbers, i only get letters. This is when I am setting up the printer for the first time as a wireless printer. I have a Mac Pro
  • 32 Answers
Usually it goes through caps and lowercase then numbers. so like it would be a-b-c-A-B-C-1 if that makes any sense. and also some printers actually have a menu where you can type with the arrow buttons and you can switch to numbers on there.
Posted on May 10, 2009
How to switch from number pad to letter pad on my HP printer M476DW
If you want technical support of HP, you can contact us on HP Printer Tech Support Phone Number 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/jhx3XY
Apr 21, 2015 | HP LaserJet Pro 400 color Printer M475dn
How do I switch from letters to numbers on my canon Pixma mx 452 printer
Use the Tone key to set the keyboard mode for each character. You will see the mode as a, A, 1 (designating the keyboard will be entering lower case, upper case and numbers, respectively)
May 18, 2013 | Office Equipment & Supplies
How to make default tray 2 in HP Laserjet p3005n printer
HP printers will default to the highest numbered tray that contains plain letter paper. So on a standard 3005 Tray 2 is the default unless you have the paper type set for something other than plain letter. If you have an additional tray, then Tray 3 would become the default tray if it is set to plain paper. In this case, you would set tray 3 to either bond or letterhead so that the printer would only grab from that tray if you request either tray 3 be used or create a job that calls for that type of paper.
If this does not sort it out, post back again with a complete description of the printer including number of trays, what is loaded in the trays and how they are set for both paper size and paper type. This information can be found by printing a configuration page. This is done by pressing the arrow key on the control panel until display reads information, press checkmark (green button) then use down arrow until Configuration page is displayed and then press checkmark again. Page will print that shows all the settings for the printer.
May 08, 2011 | HP LaserJet P3005n Printer
I have a Samsung SCX-5635 multi-function printer/copier/fax & scanner. It worked great with my old IBM desktop computer running XP. However, a few days ago I upgraded to a new HP custom built HP...
Are you sure the driver is set to A4 paper and not Letter Size. Letter size is the default. Letter size being larger than A4 would mean the print would be off the bottom so you wont see it. Could be as simple as that.
Apr 23, 2011 | Samsung SCX-5635FN All-In-One Laser...
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
Jan 27, 2011 | HP OfficeJet 6110 All-In-One InkJet...
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
When entering a WPA key in the network settings of my HP OfficeJet 6480, how do I toggle from letters to numbers?
When you enter the WPA key, use the appropriate key on number keypad on the front panel. Keep pressing the appropriate key until the desired letter (upper or lower) appears.
Once the correct letter is displayed, wait a second or two and the cursor will move to right so you can enter the next letter or key.
A second option is to connect the printer to your using the wired connection and then open the web interface using the ip address of the printer. Login to the printer then go to the wireless security settings and enter the Pre-Shared Key (WPA key).
It's also a good idea to put a check mark in the "Obscure PSK" option box as an added security measure.
Jun 04, 2009 | Digital Products Hewlett Packard OfficeJet...
Iam facing in hp 4050 printer,when i have giving command from tray 2,printer is giving error on display 41.3 unexpected paper size but from tray 1 is working ok.i have done already in paper handling menu...
swap trays and test - if OK then your tray is set up wrong. remove paper and check that it is set for letter. also check the small switch (if there is one) on the Right hand side of the tray that maybe set to customer - change to standard. compare trays so they look the same - and check the settings in the menu for letter / plain on both trays
Jun 04, 2009 | HP LaserJet 2840 Printer
Fonts are the same when its printed out.
go to control panal > printers and faxes folder> right click on the hp printer icon and click properties>
look for the printer settings and the setting called "resize or fit to page" and switch it off.
let me know if u need details. i dont remember of the top as the section where it is is different for different printers.
Oct 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer problem
Your printer is asking for letter size paper to be put into the main tray. If you have the tray set-up to legal or something else, reset the tray for letter. If you need legal or something else in the main tray, place letter in the manual flip down tray and press the "on-line" button on the printer to bypass the tray selection.
Aug 25, 2008 | HP LaserJet 4 plus Printer
HP All-in-One Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
