We have a Halstead Ace High combi boiler with a persistent intermittent fault. ( 3 months.)It keeps going to 'lock out' - Sometimes it can be restarted by resetting but not always. Sometimes while just running the heating but also it will lockout when using the shower. We have had a new PC board fitted and 2 leaks around the manifolds and micro switches have been repaired. Every possible pressure (gas
  • c_whitehorn May 10, 2009
    The model number as far as I can see is 'Ace High'
    Scholar:
  • 83 Answers
You need to get a qualified 'Gas Safe' engineer to check the Venturi in the flue, and clean it out. The other thing to look at is the igniters, clean them wirth emery paper as this boier relies on flame rectification (ignite and sense flame)
The other important aspect which also hasn't been mentioned is to check the inlet and working pressure (as i have had a faulty gas meter governor before)
Quite often the simple faults are overlooked and everyone goes for the PCB, It is doubtful it's a loose wire on the gas valve, The best advice is to get a gas engineer in and for him to call Halstead while on site.
Be very careful when working on your own gas boiler, as any mishaps, and your house insurance is void.
Posted on Jul 10, 2009
  • 163 Answers
What is the model number? Do you know the fault number?
Posted on May 10, 2009
Hjjgh
Posted on Jan 31, 2012
    Sergeant:
    Champion:
  • 219 Answers
Well there seems to be lot of faults in ur applicance and my advise would be to go to service center as there are lot of problems in it and as well as it been for quite some time.You will not be able to handle all this.
Thanks!
Sandy
Posted on May 14, 2009
  • Sandeep Gupta May 14, 2009
    but before it u can try this
    The problem may be with loose electrical connection to the gas valve
    inside the boiler which appeared to be not allowing the gas to flow
    through thus not igniting and so the cut out operates after several
    attempts. there is a wiring diagram on the inside panel and the
    connecting block was visibly loose so it was easy to see but i wouldnt
    advise you to go fiddling around inside and certainly shut off the
    supply if you do open the panel.
Hi, my halstead ace high boiler has started losing pressure and when i top it up to put the heating on after 10 mins the pressure is high whats wrong with it?
Probably a waterlogged expansion tank. The tank provides a springy air cushion for the water to push against as it expands, and the air pushes back as the water contracts. This scheme minimizes the pressure change that would otherwise be caused by expansion and contraction of the water, giving the water somplace to go when it expands. If the air cushion is gone ... big pressure swings.
Dec 28, 2009 | Water Heaters
Halstead ace high boiler making a whining noise when central heating is turned on also pressure reduces after about 4 hours, need to top up verey day.
Whining = pump bearings
Pressure reduction = pressure relief valve diaphragm either perished of gunged up - look for water coming out of the overflow pipe from the valve
leak in ch system look at all joints
Nov 30, 2009 | Water Heaters
I have a Halstead High Ace which will not light up the light flickers then goes off we have fitted a new dectection electrode but still will not light the boiler We also have flushed the system out ....
sounds basic, but make sure the electrode is in the pilot flame
check the overheat thermostat is not jammed on
disconnect and join wires together for temporary override check and run boiler.
Nov 14, 2009 | Water Heaters
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Mar 31, 2009 | Water Heaters
Heating & Cooling Logo
1,176 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
