Home | Shredders | My techko SH 3112Fa won...
Shredders
Problem for Shredders
Generic problem for all Shredders
My techko SH 3112Fa won't turn off
By savannah320 on Oct 11, 2007
It keeps running even when empty and won't turn off unless I unplug it
Comments:
Nov 25, 2007
- I have tried and tried to clean out the shredder, but still am having no luck shutting it off. I appreciate your help and have changed the rating, but it really did not help. I knew what the probem was, but can't figure out how to fix it.
Thanks anyway.
Same Problem
Dec 17, 2007
-   yes im having the same problem-   tpaskes
Dec 05, 2007
-   The plastic paper guide is broken.Therefore, the paper continues to wrap around the blades.
Were can I obtain a new cover?-   Guest
Nov 30, 2007
-   I, too, am having a problem with the shredder not turning off.  I took the cover off and cleaned the unit completely.  Still runs continuously.  Solution?-   Guest
Nov 11, 2007
-   I cleaned the shredder and it still won't shut off...-   Guest
Best Solution
posted on Jan 16, 2008
Very Helpful)
martinuk777
Rank: Apprentice
Rating: 100%, 1 votes
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Was this helpful?
Yes
No
Solution #2
posted on Oct 12, 2007
Somewhat Helpful)
24 seven
Rank: Wiz
Rating: 82%, 1397 votes
the paper feed unit must be cleaned of all paper pieces that have lodged inside. some pieces are making the paper detect switch send a false signal to motor.
Comments:
Nov 22, 2007
- hey savannah,
why did you rate me as inappropriate? What's up with that? At the very least it should be "thanks for trying"....you CAN CHANGE IT to "thanks for trying", you ARE allowed to...I really am upset with this...
Nov 22, 2007
- look, the switch is stuck, one way or another...it must be UNSTUCKED!
Nov 23, 2007
- hello...anyone there?
Was this helpful?
Yes
No
Solution #3
posted on Apr 17, 2009
Not Rated)
jworfolk
Rank: Apprentice
Rating: 90%, 1 votes
If the machine has auto-detection, then the sensors in the paper throat are probably dirty with paper dust. With the sensors blocked, the machine thinks there is paper in the throat so it will continue to run.
Was this helpful?
Yes
No
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
i need the small circular tube that is installed in the mouth of an ativa 1000 paper shredder
Answer
Shreader fits on a generic waste basket, runs in reverse by won't shread forward
Answer
the gears have broken off on the shredder i need to know how much the to gears cost for the two... (More)
Answer
We were shredding - a red light has come on & stayed on - looks like an upright saw/teeth -... (More)
Answer
My SPL616x Shredder I had a jam and I cleared it up. It runs in reverse but not forward Any advice?... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shredders:
Top Shredder Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
