Question about GE GBS18HBR Bottom Freezer Refrigerator
Freezer freezing ......top not cold
Freezer freezing top not cold GE GBS18HBR ww
Verify the fridge "flap" which could be stuck closed. To do this remove the shelves and then remove screws holding the center panel (3 screws for a bottom freezer). At the bottom you will find a connector which can be unclipped so you can take the panel out completely from the fridge. See if the flap is closed if it is then that could be the problem. It may need to be replaced. Good luck.
Posted on May 03, 2010
The temperature of my GE Model PSH23PGSD in freezer and refrigerator will not maintain 0 and 34
heat rises so if it's cold on the bottom and warm on top in freezer it sounds like you have a bad evap fan motor,when you open the freezer door do you hear the fan blowing,if not look around and hold the door switch in and see if it blows on some models fan won't run unless door is closed but if no fan you have a bad fan motor,the problem with ge is everything runs through the mother board located in the back,also i've found that the fan blade slides off or out of position on the shaft and it just doesn't move any air but you have to find out if it's the fan motor or the board,also the fridge should be set at 37 or 38 not 34,if your handy and you're going to fix this yourself,i would get both parts from repair clinic because you have 365 days to return parts,change the fan motor first if it sounds like the fan is your problem and see what happens,this way you have both parts and you can fix it that day and send back any part you don't need,if that's under 8 years i would change the fan motor,it's cheaper than the board if this is what's happening.hope this helps and good luck
Sep 29, 2017 | GE GBS18HBR Bottom Freezer Refrigerator
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
GBS20HBSBWW BOTTOM FREEZER, MAKING LOUD NOISE WHEN I TURN THE ADJUST KNOB IN THE REFRIGERATOR TOP TO 0 THE NOISE STOPS.
It sounds like your fan is hitting something. Usually there will be an ice block or something in the freezer pushed in on the back and cased the fan or wire to move ect... I hope this helps
Aug 11, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
My refrigerator is not cold. There is frost in the freezer and it is running constantly.
remove form the wall 5inchs, unplug for 30 mins, clean behinnd. let it in that position and plug back.
Aug 06, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
GE GSS25LGMA WW FREEZES FOOD
These refrigerator use the cold air from the freezer the cool the refrigerator. At the rear of the upper refrigerator compartment, there is a shroud. Remove the shroud and you should see a "flapper" that shuts off the cold air when desired. You will most likely see the flap is broken. Once the flap is broken, you lose control of your refrigerator temp. This is a common problem with this refrigerator.
Hope this helps.
Jan 11, 2009 | Refrigerators
GE GBS18HBR Bottom Freezer Refrigerator Logo
254 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
