How do I take off the flat top panel of an older Kenmore front load washer. I don't know the model #, I believe it was made in 2000.
How do I take off the flat top panel of a older model Kenmore front load washer
  • 478 Answers
The screws are in the top back some are specialty heads, should be 4
Posted on May 10, 2009
I got the top off the washer, and now I cannot find any way to open the front panel of this top loading washer. It is the Atlantis MAV9750AWW.
Most don't have a front panel. Just top panel and rear panel.
Did you raise the top panel?
There are clips there that you have to find with a flat knife type tool.
Jun 26, 2011 | Maytag Atlantis MAV7551 Top Load Washer
How do you remove the front kick panel
Here are the steps.Hope this helps.
Insert a putty knife between the top of the kick plate and bottom of the front panel near the center of the washer, if you have an older model top load washer. Move the putty knife blade in and out in that area until you feel an obstruction. The obstruction is the kick plate retaining clip
Press the putty knife blade over the spring clip until you feel the clip disengage. Let go of the putty knife and grab both ends of the kick plate with your hands. Pull the kick plate away from the washer
ift the front of the washer with help from a friend, if you have a front load model Whirlpool. Slide a block of wood under the front of each side and gently lower the washer Remove the three hex head screws on the bottom edge of the washer kick plate with a Phillips-head screwdriver or nut driver. Pull the kick plate away from the washer.
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
How to remove back of washer
Hello, Thank You for using FixYa. I will be helping you today.If its a front loader just remove all the 1/4 inch screws from the back cover. If its a top load remove the control panel back corner screws flip up control remove two clips unplug lid switch and remove the whole cabinet.The back does not come off the top load whirlpool.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Whirlpool Washing Machines
TROUBLESHOOTING KENMORE ELITE HE3T FRONTLOAD WASHER WITH THE ERROR CODE F70
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2009 | Kenmore Washing Machines
Describe your Kenmore 24032 \ 24036 Top Load
Hi, Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
If this is not your model, please let me know the model# so I can help you.
Vic
Jun 28, 2009 | Kenmore 24032\24036 Top Load Washer
Front load kenmore washer giving error f20 messsage.
take the kick panel off and find the tech sheet. i believe you have3 either a bad pressure switch or something stuck in your pump. let me know how it goes
Apr 04, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front loading commercial washer door will not opne
You need to get access behind the front panel, taking the top panel off is probably best. Then you can see the the door release mechanism and release it.
Feb 09, 2009 | Kenmore 43042 Front Load Washer
Can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Jan 23, 2009 | Kenmore 24032\24036 Top Load Washer
Cant release top panel
if you are talking about the springs that look triangular in shape you use a putty knife or small flat screw driver and push the spring inwards. the top of washer will pop up. repeat with other spring. top will lift up now.
Jan 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
