Posted on May 10, 2009
Error message "Can not find camera.Please connect Omnivision SuperCam!" on my Vista laptop. Scanner works fine on my friend's XP desktop. Have tried all steps outlined in manual (several tim
Vista laptop keeps giving error message "Can not find camera. Please connect Omnivision SuperCam!" No problems on a desktop computer running XP ...scanner works fine. But, the laptop is mine, the desktop is a friend's. Help.
  • BEJ64 May 14, 2009
    I have the same problem Summit Photofix Copier using Photo impressions show Can not find camera on my new Vista Pc but worked on Xp
  • onceafalcon Jun 14, 2009
    Thanks, tukr,...it is connected directly into the laptop. But, I'll give it another try.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3831
Points
Tengo el VISTA, Al tratar de escanear diapositivas con un reflecta x2-scan, cuyo sofwar he instalado, me da exactamente el mensaje que reseñan "Can not find camera. Please connect Omnivision SuperCam".
¿Como puedo activar dicho dispositivo?
Anonymous
Level 1:
  • Posted on Jun 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3831
Points
On my Vista desktop it worked directly, but I had the same error message on my Vista laptop when the scanner was connected through an USB hub. Perhaps the power is not sufficient?
Then i plugged the connector directly into the laptop usb port 2.0, and the driver was automatically installed and works fine!
I have been using a Belkin G+ wireless modem for the last year on a laptop on Vista and desktop on XP.I have now bought a Belkin N wireless kit and it has connected the laptop fine but when I try to instal...
Instead of double clicking the icon to install the program, right click on the icon and click run as administrator. This should give you the permissions you need to complete the install.
4helpful
2answers
I have recently bought a packard bell easynote mx37-t-003 laptop with an integrated webcam, however after using search commands, scanner and camera app i still cant get it to work! any ideas?
If it is XP, you should just click on the Camera icon in Control Panel. If Vista you have to install an application. Try MSN Messenger and connect to a friend with video link or google picasa.
2helpful
2answers
Hey there, I was trying to
I guess I found a solution for the problem.
I also got this error message after installing ControlCenter3. Failed to start ControlCentre3 - re-install software, with the error No CC3-001-00001907. The numbers at the end can change, but that's not important.
I have two laptops running vista. I got this error with the 1st laptop. Then I tried it with the second laptop, it worked fine. That made me think: On the first laptop I had tried to install the ControlCenter3 from the CD, but it turned out that the CD did not support Vista. Then I got the vista driver/ControlCenter3 package from the Brother website. This is the one that did not work on laptop one. What I then guessed was, that I had some ugly remains from the installation of the old driver (not for vista). I started cleaning the registry. First of all I run the driver uninstall program from Brother (free from their website) then I cleaned the registry with CCleaner (freeware). Still that was not enough. I started the regedit program and started searching for the term Brother. It was still there in about 10 or more places. I deleted all records that were connected with my brother printer (a DCP-130C). Then I run CCleaner once more. Then I installed the vista driver package (from brother website). Restarted and voila: it worked. ControlCenter3 workes fine now. I started the ControlCenter3 update (also on brother website) and finally with the scanner utility put the scanner resolution limit up higher. That's it.
Before working with the registry make a backup, please.
This procedure should also work for other brother printers using the controlcenter3. It should also work for other systems than vista.
Cheers, hope this was helpful.
Edi
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
Camera and scanner no longer recognised
On Windows 2000, XP, and Vista, you can get to Device Manager by right clicking on your desktop's "My Computer" (or "Computer" for Vista) and select "Properties". Then click the "Hardware" tab. Then click the "Device Manager" button (Vista may be slightly different).
As for why they are recognized on your friend's laptop but not yours, it's going to depend on what operating systems both are running and what the brand/models of the camera and scanner are. If there are drivers required to run the camera and scanner, try uninstalling and reinstalling them.
2answers
MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
k24674
ADMIN Andrew
ADMIN Andrew
