Question about Canon PowerShot SD1000 Digital Camera
Photos washed out or completly dark
I have experimented with many various combinations of settings, but I can never get consistent shots. Even if I have it set to Auto, and take the same photo several times, each one is either completely washed out, or completely dark. My brother has a degree in photography, and even he can't figure it out!
  • Canon Master
  • 4,738 Answers
Sorry to say this sounds like a stuck shutter mechanism. Put the camera in any mode other than auto and make certain that you turn the flash OFF (you don't want to blind yourself in the following step). Next look down the center of the lens barrel and take a picture. You should see a tiny flicker (wonder where that website got that name?) in the center of the lens as the shutter opens and closes. If no movement is seen then it's likely stuck.
Some people have had success in unsticking Canon S2 IS shutters with the following procedures. It may or may not work for you:
http://www.fixya.com/support/t295396-canon_s2_black_screen
Posted on May 10, 2009
Olympus e420 no live view black images
are the photos on the memory card? LCD could be shot or loose.
Mar 12, 2014 | Olympus Cameras
Photos taken inside are fuzzy
i think the exposure settings have changed and set to hi if you can get the exposure setting to normal [+/-] to 0 or the shutter has been set to low or the iso has been set to low
but if u are skeptic about going to settings and changing those all important combinations then safest way is to restoring to factory defaults and from there u can keep experimenting again
if there is anything else that you would like to know u can mail me at mail2pvs@gmail.com
happy clicking
Jul 14, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Blurry photos on the Sony DSC 170
This issue often is related to lighting, subjects in the foreground, and the lack of optimal settings when using the Easy / Auto function.
First, you should look at subject matter.  If you have the camera set to Easy / Auto, it will focus for you.  This is good if the subject of the photo is the only thing (or the nearest thing) in the frame, however if there is anything else closer to the camera, it will assume that the nearest object is the one being photographed, and will adjust accordingly.  Although it may be something large such as a chair, sofa, table or even a houseplant, it may also be focusing on something as small as a child's toy.  If you must use the Easy / Auto function when photographing your children, make sure that your children are the only (or the closest) subjects in the photo, and the camera ought to set the focus on them.
The second issue is lighting.  Even when using the easiest settings on this camera, you still must make sure that the lighting and flash are optimal.  The flash, for instance, can be set to three different intensities, as not all situations require the same amount of additional light.  Make sure that if photographing indoors, you have either a decent amount of lighting, or the flash set to add the appropriate amount of additional light.  If the area photographed is too dark / bright, the camera (when set to the easiest settings, without any additional specifications from the user) will have difficulty finding (or choosing) the main subject of the photograph.  This is why you will occasionally see multiple little green squares, when it looks (to you) as though your children ought to be the primary --and only-- focus of the photo.  In simple terms, the camera is confused, and will choose what stands out as the main subject.
Remember that although this camera is technically of the point-and-click variety, one of the things that makes it stand out as a digital camera is the ability to adjust the settings as the situation dictates.  I suggest learning what each of the camera settings are used for (it seems daunting at first, but I assure you that it isn't as difficult as it first appears to be... remember, this camera is technically for those who have little-to-no experience with photogrpahy) and applying the available settings to the photos you take.  I am able to turn on my Sony Cyber-Shot DSC W170, adjust the settings to the situation, and photograph my children in less than two seconds more than it would take to turn it on and set it to Auto.  I have taken photos with this camera that have come out beautifully enough to print at the actual stated 8"x10" size (which is rare for a point-and-click), by adjusting only the ISO and flash (and nothing more) to accomodate the setting.
If you are looking for strictly a point-and-click camera that you do not need to set anything on (essentially the digital version of a quality 35mm disposable camera), there are some excellent ones on the market today.  I would reccommend the Sony Cyber-Shot DSC W170 to those who are looking for a camera that is slightly above "beginner" level (though well below "expert" level) cameras.  My husband purchased this for me as a birthday gift, to have on hand for quick photo-taking (quicker than setting up a tripod and adjusting my primary camera) while out and about with our children.
I have been able to take some very beautiful photos with this camera (three outdoor photos were nice enough to sell), however I have only made use of the Easy / Auto settings a few times, while playing with the settings after first receiving the camera.  There are other beginner-level point-and-click cameras that, in my opinion, take far better digital photos than photos taken using the Easy / Auto functions of the Sony Cyber-Shot DSC W170.
This camera was designed for consumers who make use of the various settings, to ensure an optimal photographic experience (much like the difference between a professional photographer's 35mm camera and a basic 35mm camera).  For this reason, anyone looking for a camera that is an easy, simple point-and-click (i.e. you turn it on, take the photos, and that's it), I would suggest shopping around for a simpler camera.  There are many excellent ones that are designed to be quick and easy, and take good quality photos, without needing to adjust anything.
Dec 26, 2008 | Sony Cyber-shot DSC-W170 Digital Camera
Dark photos
first open the cover of the power shot and take photo
Aug 16, 2008 | Canon PowerShot A530 Digital Camera
Everything is so dark!
If the camera is working properly with other lenses, then you have a problem with that lens. In M, you can set the aperture yourself, and the photos come out properly exposed. When the lens is set to auto, apparently it is going to minimum aperture and not responding to the camera's 'instructions'. The thing that makes me think so is that you say everything looks dark through the optical viewfinder. Normally the aperture stays full open so you can see and compose your shot, and only stops down to the correct aperture when you actually take the shot. I would suggest having the lens checked by an appropriate camera service shop.
May 29, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Dark downloads
I don't have this camera so I'm not sure about your pictures being dark but. There is an easy way to fix them in bulk.
Google makes a great application called Picasa that will let you do simple edits to many images at once.
http://picasa.google.com/
I suspect you could lighten all your pictures easily with this software instead of one at a time.
Apr 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
All photos underexposed, changing settings does not help
defective shutter curtain opening, it needs pro service. Shutters have life expectancy around 5thou to 10 thou shots.
Jul 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Flash and Shutter not in synch
Good Day, flash assy is defective, the light sensor that will detect the correct flash exposure is defective, no longer user serviceable, contact nearest svc ctr for replacement of flash assy. thanks
Nov 19, 2006 | Sony Cyber-Shot DSC-P73 Digital Camera
Dark Images Indoor
This may sound dumb but is the flash going off? The second thought is how far are your subjects from the on camera flash. As you're probably aware, the flash is challenged as the distance doubles; half the light at twice the distance from any point. An equivalent example; f/4.0 @ 1/125th of a second worth of light at ten feet but you'd have only half the light available at twenty feet. So you'd have to change either your f/stop or shutter speed by one stop to either f/2.8 or 1/60th of a second. This is why the distance is so important. I don't see a hot spot on your subject matter so I'm guessing the flash isn't going off. Could be wrong as you're there so you'd know.
Sep 13, 2005 | Kodak DC4800 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
