Question about Mitsubishi VS-50805 50" Rear Projection Television
Messed up Image
Okay, so here's the problem.  I bought the TV back in 1999 and up until around June I had no problems with it.  Then one night, the video seemed to flicker slightly when I was watching a dvd.  Thought nothing of it, went to bed.  Next day, turned the tv on and here's what everything looked like:
I did some initial research but came up empty handed and only to try a hard reset by unplugging everything, letting it sit and trying again.  I did this and 4 days later (without using it) I plugged everything in and it worked fine.  I didn't use it much over the course of the next few months, but it did this same exact thing twice.  It seems like it'll act like this, then after sitting off it'll go back to normal for a while, then right back to this.
Most recently, I turned it on, everything was fine.  Let it sit with my satelite on for a while, then it randomly went right back to this.  I didn't hear any clicks or pops when it switched back to this messed up mode.
Here's a closeup of the screen:
Some reading makes it seem like the convergence is way off, but I can't adjust it through the TV's screen settings.
Anyone know what's wrong?
Thanks,
JB
    Genius:
  • 1,694 Answers
Soldering convergence amps is a temporary fix........Since the
labor is about the same,it's best to change-out both Ic's.Your
pix should return to near normal,with minimal adjustments
needed.....................T.
Posted on Nov 20, 2007
  • 59 Answers
Bad connection on convergence amps or need to replace them
Posted on Oct 31, 2007
2 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: Messed up Image
You need to replace both of the convergence ICs. They are both STK392-570 you can get replacement ICs at the following link and they provide free instalation instructions with pictures on how to replace the ICs. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 08, 2008
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Why does tv have double color picture appears in three d?
u need a tech to reset the tv convergence problem the cost depends with the tech and your area check with your nearest tv repair shop
Jul 11, 2013 | RCA P61930BL 61" Rear Projection...
I had a power surge last night and the video on my plasma is out. I have audio but no video??
I just replaced my bulb (XL2400) on my rear projection TV. I go to plug the bulb back into the TV and I get the error (red light flashing) that indicates that the bulb or the door is not securely in place. Is there a trick to getting the bulb back into the proper place. I messed around with this for over three hours last night.
Feb 19, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Sony Bravia KDL-37M3000, bought June 08. The
Get a digital antena,If u using the signal over the air,rescan.If the signal is cable or other pay tv signal.Ur digital turner,it damage.
Jul 09, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
TV won't come on.
Few items here, most likely you have a Blown Fuse in the power supply of the TV. 2nd a power strip / surge protector is good to an existent but you will be best protected by a Power conditioner from monster power supply sold in many Best buy stores. 3rd if you can or have a freand that can. Inspect the power supply of the TV for a deformed capacitors main failure to most power supplies in LCD & plasma TV's
Jun 25, 2009 | Televison & Video
Cracked Screen for a Panasonic DMC-TZ4
Not worth replacing screen, due to labor cost so if camera works, it can still be used for snapping up shots if set on automatic and can be connected to monitor source e.g. gps monitor, portable TV,etc to view pics or change settings. Can try selling cheaply online and use money for new camera.
Nov 14, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Messed up Image
Jul 08, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Game Mode
Had the same problem. You have to get a universal remote that matches the tv. Bought it today at Kmart (Walmart has it too). Only set me back $10-11 bucks and most def. worked. Set it to the tv and hit the Input button, GAME mode came right on. Here is what I posted in another forum on here.
I had the same problem until today. I bought the same tv and went to Kmart/Walmart. I bought the RCA Universal remote (RCR412SI). Only set me back $10-11 bucks. Has like 3-4 ways to set the tv, dvd, sat-cable and vcr/aux. Even allows several tvs I believe. Couldn't set it at first, then there was the other method where the remote did the search. Worked! Here is the device, http://www.walmart.com/catalog/detail.gsp?image=http://i.walmartimages.com/i/p/00/07/90/00/33/0007900033211_500X500.jpg&product_id=10740563&iIndex=1&isVariant=false&corpCard=false&type=-9223372036854775808
I hope this helps everyone out. If you have the 6419TC 19" TV, it will work, just make sure you read
the directions and be patient. Will save you money.
Jan 21, 2008 | Sylvania 6419TC 19" TV
GE 31GT660 picture is intensly WHITE
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Aug 22, 2007 | GE 31GT660 TV
Toshiba 50H72 Rear Projection Television
no you wont be able to fix over the phone it requires replacement of the stk packs
Dec 04, 2006 | Toshiba 50H72 50" Rear Projection...
Mitsubishi VS-50805 50" Rear Projection Television Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
