Question about Kenmore Dryers
All the electrical lights are working but the dryer will not start. We tried to clean the dust area(where you unload all the dust), after that the dryer stopped working. Does anyone have any adive?
I have a Kenmore Elite, model 110 70052990. It recently stopped working. I had a technician that came out and said it might be electrical but was not sure. It just completely stopped working. What do you think? Thank you.
  • 10,865 Answers
The dryer is on a separate circuit from the lights. go to your electrical panel and locate the circuit breaker or fuse for the dryer. if it is a breaker, turn it all the way off and then back on. if it is fuses, replace with new ones of the same amperage.
get back with any questions you may have.
Posted on May 10, 2009
Help with dryer repair???
The first thing to do is unplug it and take the bottom kick panel off. You will see a lot of lint. Get a vacuum cleaner and clean it out. Then you need to look for the heater box. It comes loose with a couple of screws and you can pull it out. Take a picture of it or write down the wire locations. Take the two wires off that go back into the machine. Then you can take it down and have it tested at an appliance shop.
Jul 07, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
My clean filter light won't go off on my frigidaire & my dryer won't turn on
Did you try to remove the back cover after unplugiging your dryer ,to find a lot of lint in the back of the dryer? Some times you may have to clean in this area for fire safety. Maybe this would sold your problem.
Jul 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
FZDC47100w
we had the same problem and didnt use our's for about a year as a result! brought it to a guy in Cork Street, Dublin. what he did was clean out the pump area on the left hand side, near the back and at the bottom of the machine. having cleared out the fluff and dust he washed it out, flicked some sensor switch a few times (under a small plastic cover he had removed on the pump unit). when he put it back together it worked fine.
Apr 19, 2012 | Zanussi TC7102W Electric Dryer
Dryer works but no heat
If a gas dryer, make sure pilot light is lit or wire to electronic ignition is connected. Make sure the area around thr ignitor is clear of dust and the filter and exhaust are clean.
If electric, check your home fuses or circuit breakers and make sure your plugged into the proper voltage and grounded outlet. Set on highest temp setting and run for a few minutes and check if your getting any heat.
Some newer dryers have a built in sensor that will only turn heat on if it detects moisture, so you may need to through in a wet towel.
Mar 25, 2010 | AEG T58840 Dryer Electric
Electric dryer keeps tripping reset button on bottom works for about 2 load then trips it s a fisher pakel top load dryer about 4 yrs old
main drive motor problemely has dust in start switch in the motor an the motor is staying on the start cycle an not switching to the run cycle you have to take the motor apart an clean it or you may be able to air blow the dust out
Dec 17, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Jun 14, 2008 | Whirlpool GEW9200L Electric Dryer
DLE2532W Dryer
I had the same problem. Really glad I came to this site. Had already tried to clean out the filter area. What really worked was unplugging and resetting the computer. Everything seem fine now.
Mar 16, 2008 | LG DLE2532W Electric Dryer
Wont heat
the sensor may need to be reset. My felt filter had come off but the dryer worked fine until everything filled with lint. Much of the lint was in places you can't get to easily and Fisher Pykel doesn't mention cleaning these areas in their manuals. I know it is to late to help you but it may help someone in the future.
Nov 15, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
90 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
