Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi ultravision 52 inch plasma
The volume isnt working...there is no volume at all. It worked fine the last time we used it. We had this problem once before and dont remeber how we fixed it.
Any ideas?
PS the volume does work , when the cable is off.
  • 1694 Answers
SOURCE: 43 inch Hitachi UltraVision model # 43UWX10B
Research at
Posted on Nov 10, 2007
  • 1153 Answers
SOURCE: 52 hitachi ultravision
Yes, you can search these threads for the answer or
Posted on Jan 02, 2008
SOURCE: hitachi ultravision tv
watching tv when electricity went out everything came back on except tv
Posted on Jan 19, 2008
hitachi 43uwx10b will not turn on. red power light just flashes
Posted on Apr 06, 2008
  • 121 Answers
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
Posted on Apr 13, 2008
  • 10594 Answers
SOURCE: remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Posted on Aug 02, 2008
0 characters
1 Points
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Jul 31, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hey, I found this on a blogsite about lcd rear projections....looks like our tv's screens have been burned by the "pillers" that surround the tv when switching from 4:3 to 16:9 or fullscreen... read below, I hope it helps !
Rear projection crt's,the first generation widescreen tv's were notorious for that.Lcd and plasma can have the same problem,but it takes much longer and is not as harsh.Dlp's use tiny mirrors,so it isn't a problem with them.Lcd and plasma tv's should be ok unless you watch them with blck bars on them all the time.
We have lcd monitors at work,and i've seen them after a year with bad burn in.They also run 24 hrs a day 7 days a week with the same display.
GKar posted 2006 Oct 10 15:31 TooLFooL : i have 51" sony rear-projection and those freakin' grey bars burned themselves right into the screen...
I read that to avoid the burning you had to limit your 4:3 viewing time to 15% of total time viewed. (applied to my TV but apparently yours and others as well...great! now they tell you :-x , this applies unless 4:3 aspect was changed to stretched or zoomed...yuck :-x )
This really sucks as a Star Trek/Lexx/Farscape fan as they are mostly 4:3, fortunately the upconvert player/hdmi combo sends a 1080i 16:9 signal to my TV so the effects are drastically reduced by nearly filling the TV without the grey bars or burn in problem without stretch or zoom modes being used. yay! :wink: (default grey bars set to black automatically, apparently grey isn't needed due to screen area covered is sufficient for burn in not to be a problem.)
Apr 11, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50SX6P 50 inch television
Friend gave me a Hitachi Ultravision 50SX6P
I can see why ... he got rid of it
anyway...I need the manual
How can I get it
Need to get rid of yellow outlines
Jan 03, 2008 | Projection Televisions
Jan 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Plasma t-v with a red line
hemp, your model comes up as LCD not plasma, If 55VG825 is the correct model # them I`m sorry to give you this but thats a bad optical engine symptom, big bucks to fix, sorry to be the bearer of bad news, BMW Rider
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision rolling horazontal lines
Mine has the same thing when I have a Component AV S-Video Switch (one that can have muit- rca connections along with coax TV line on it ) the component switch caused interference and caused that line
Oct 14, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
85 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
