Question about Canon PowerShot A520 Digital Camera
Powershot sd750 in water
Hi!
today i was replacing a battery in my canon powershot sd750 when it accidentaly fell into my dog's water dish. It was only partially filled and i managed to pull it out within 10 seconds. I removed the battery and dried the outside and as much of the inside that I possibly could. Then, i turned it on and the lcd was simply not bright enough to see. It would flash on and off with brightness levels. I let it dry some more and now the lcd wont show up at all. is there anything that I can do to fix it, or is it ready for the garbage? Please help me to figure out what the problem is, because I love this camera!!
thanks for your help
  • Kimmbo Jan 04, 2008
    I too have a water issue with my PowerShot SD750. My son's sippy cup accidently leaked in my bag where my camera was. Fortunately, very little water got on the camera, but it is no longer working : (
    My camera is just 3mo's old - help!
    Champion:
  • 217 Answers
You still have time to clean the unit!!! waiting for even a week will result in internal corrosions, you have to seek professional help to fix it as soon as possible.
Posted on Oct 12, 2007
SOURCE:
I have a Canon SD750 camera. It was the victim of a water flood and I dried the unit completely. After recharging the battery, I couldn't get it to power up. I took the camera apart and found several...
Unfortunately with water damage the camera may work for a few days or even weeks after you first dry it out, but then it will stop working completely. If you have corrosion from water exposure then the camera is gone, it's not worth trying to fix. Even if you replace the main PCB it probably has damage to the lens, LCD screen and flash as well.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a Canon PowerShot SD750. I dropped it and
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
Jul 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Water went in my cnon powershot sd750 camera and i was getting dull and blurred images and when i turned the lens it stopped workingit became dead.its just blank now.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You would need to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 21, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Water spot behind lens ?
the lens has to be replaced repair cost is 85.00 for this to be done.
Jun 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon sd750 does not hold date/time setting
yes there is a internal battery the camera has to be opened up to replace it. we replace the battery on this model for 45.00
Jan 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon powershot dosnt turn on
your camera has one of two issues.
  1. blown fuse this requires micro serface mount soldering.
  2. bad battery door switch
if you can not repair this or reather a shop do it we charge 75.00 plus shipping to fix it for you.
This is only a good price if their is no water damage and no lights come on at all.
Diagnosis is free.
Dec 30, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Nov 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Sd750 powershot in water: lcd problems
My guess is that you damaged it by inserting the battery prior to properly drying the camera. Chances are that you shorted something out when you powered up with water still inside the camera and if that is the case I would suggest placing the camera in a sealed bag/tupperware with some dessicant (a material that removes moisture form the air) and the battery compartment left open (and the battery out). Try powering it up after several days, I doubt it will work, but it won't hurt trying. Then call Cannon to see how much it will cost to get serviced. DO NOT MENTION ANYTHING ABOUT DROPPING IT IN WATER. Just say it stopped working one day. I really suggest using a dessicant because if they open it up to fix it and find any noticable water, you will be SOL and it won't be covered under warranty.
Oct 11, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A520 Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
