Dell dimension 4600C Power up issue
My power button just blinks when trying to turn on. I have replaced PS and fan and same issue.
  • mbausa Mar 28, 2009
    Dell dimension 4600. the pc won't power up for few days. no sign of power at all. After a few days, the lights start flickering. I press the power button and starts up. Anyone? thanks
Reseed your memory then flash bios
Posted on Jan 31, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
This might be a problem with your motherboard or processor or both of them.
Posted on Oct 12, 2007
SOURCE:
Dell Dimension 4600C PC Desktop smells burnt
Issues like this should be reported to Dell , if your system is still covered by a warranty then they can send a tech to further check it.
Burnt smell can come from several parts of the system like power supply , motherboard , fan , etc. and it can be hazardous if not checked by a professional.
What I suggest is that you call Dell technical Support.
Hope this helps
Thanks
Dennis
Oct 27, 2011 | Dell Dimension 4600C PC Desktop
Dell Dimension 4600C Compurter running fast and
Try to check the fan and the inside of the desktop for any dirty things in there. Especially check the fan to see if something is stuck!
Mar 04, 2011 | Dell Dimension 4600 PC Desktop
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Dell Insp 4600C blinking yellow power light
the issue could be woth the power supply unit or internal wirings ..
Jul 19, 2009 | Dell Dimension 4600C PC Desktop
I have a dimension 4600c. installed a new power
The power supplies have extra connectors which are not used.
Try doing a system restore to an earlier date when your computer was working ok.
Restart your computer and hit F8 while it is booting. When the menu comes up, select "Last Known Configuration"
This will bring it back to a time when it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 11, 2009 | Dell Dimension 4600C PC Desktop
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
Dell 4600c will not power up -- green power button lit -
i think it may not power supply problem.it may be ram memory problem.try this,remove your ram and clean it with cloth and restore back.
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Woops -the blinking amber light of doom is a common fault on dells - as you already have replaced the PS that leaves the motherboard.
usually a solid amber is the PSU while a blinking one indicates MoBo problems. If either machine is still under warranty dell will replace it.
If not then it will cost you to have them replaced.
cheers Pete
Dec 07, 2008 | Computers & Internet
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
FLASHING AMBER LIGHT FIX. This maybe in fact a motherboard issue, but actually its a bit more. You can and should replace the power supply with a more powerfull one as it will help overall, but the issue is Really the front USB ports and 2 issues concerning them, 1 some devices pluged into them have boot sequences of their own, (remember your boot seq goesfrom,USB,CD,ARRAY)etc.
So if the device isnt design with its own OS, the mis-boot will get stuck Hence the Flashing light. and 2. the front USB ports dont supply alot of power upon bootup. and the devices pluged into them will again cause a mis-boot. Simply unplug everything from the FRONT usb ports. You may have to shut the computer off and unplug the machine for about *15* minutes.
Enough to get the motherboard to downpower completely.
with the front usb ports clear, and the power cord unpluged, hold down the power button and plug in the machine. should boot no problem. So to sum things up. The motherboard is fine, it just not happy with so many usb ports (power wise). A larger power supply is a good idea but wont entirly fix the issue, Unplug front usb devices as they may have some form of bootup.
Jan 19, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
150 people viewed this question
Ekse
Alun Cox
