Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Put string on tb425cs troy bilt trimmer
HOW DO I PUT NEW STRING ON MY TB425CS TRIMMER?
  • 3 more comments
  • HARBOURENT May 10, 2009
    how do i string my tb425cs trimmer?
  • Anonymous Mar 15, 2014
    Gastank removal and replacement on Troy-bilt string trimmer mobelTB90BC
  • Anonymous Mar 16, 2014
    string will not feed through holes
    String will not go through hole and come out other side of hole. keeps getting stuck
  • Anonymous Mar 28, 2014
    I am trying to replace an old bump head on my Troy Bilt string trimmer (TB525 EC) but I can't get the old one off! I would like to see a diagram or picture showing me how, or DETAILED instructions. Other directions I have looked at online mention inserting a locking key, nail, Allen wrenches, etc. into a hole, but I can't locate that hole!
There are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Throttle cable snapped
Go On Troy Bilt .com and you have to put the model number down then you can order a new one thats the best way
Oct 04, 2012 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I am able to crank the trimmer but it does not stay on. in the past it worked just fine but sat unused for roughly 4 months and now this. we own a TB425cs string trimmer. how do i fix this issue?
1) Change out the old fuel (not just adding fresh but pouring out the old and replacing it entirely) and check the engine oil.
2) Check muffler and/or spark arrestor screen for restrictions.
3) Clean and reinstall spark plug (check gap).
4) Replace inlet screen INSIDE the carb. (It is located directly under the inlet needle.)
Try each of these as needed.
Hope this helps!
Oct 01, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
1,079 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
