Question about Dell XPS 200 PC Desktop
My dell xps wont start properly, yellow blinking light
My dell xps wont start properly, I press the power button and it only blinks yellow. I turned it off and left it off for 2 days and tried again and it turned on fine. After i turned it off again and tried to reboot it, the same problem happened.
  • Bill May 12, 2009
    Dell XPS 400 Will not start push power button amber light will flash once if i hold it in it will flash every 5 seconds, green light on MB on, Lights on ethernet connector also flash when power button pushed, fan sometimes starts to spin but only for a second, Tried disconnecting everything 1 at a time and starting but all same result, i am sure it overheated just by the amount of dust i found inside. Any ideas? Think about changing Power supply!?
    Novelist:
  • 186 Answers
Sounds like a heat problem. Make sure your CPU fan is spinning, make sure there is plenty of airflow through the chassis, check your video connection ( if it is an external card )
Posted on May 10, 2009
  • 4 Answers
I have an HP that does close to the same thing. Mine goes into a 'Perm-Sleep' mode that I can't seem to pull it out of. I have to remove the battery, then unplug the power adapter, not in that order. Leaving it in this condition for about a minute so that all the power stored in the RAM goes away. This is the same as holding the power button down for 10 to 15 seconds until it completly turns off, sometimes referred to as a 'Cold Boot.'
Once I have powered it down I have to go into the control panel and select the power settings and make sure that hibernate is not an option. If you close the lid on the laptop and the systems goes into a sleep state, it may be configured to go to hibernate after, say an hour or when the battery gets close to being drained. My computer does not like to come out of hibernate and I have to Cold Boot it, so I just don't let it go into a hibernation in the first place anymore.
Yellow blinking light on power button
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 15, 2014 | Dell Studio XPS Desktop Computer
Blinking yellow light on xps200. changed power supply. still blinking yellow
A blinking yellow light means that there is something wrong with the motherboard, if not the motherboard itself it will be either the RAM, wiring connections, bad processor or it may need a fresh coat of thermal paste on the processor itself. With Dells, its pretty easy to find out. Start the pc and You will hear some beeps count the beeps. ex:beep.beep...beep.beep which gives You a code this one being 22. Once You get the code go to Dell support and look up service code and it will tell You what the problem is. Good Luck.
Nov 10, 2011 | Dell XPS 200 PC Desktop
Blinking yellow power button xps 410 will not turn on
I suggest replacing the memory as the diagnostics lights suggest.
Memory can and does fail in some cases.
May 04, 2010 | Dell XPS 410 PC Desktop
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
Dell? OptiPlex? SX280 blinking yellow what is that
blinking yellow light on the power button of a Dell system is a possible power supply issue. press the eject button on the dvd drive while the power button flashes yellow light. if the disc trays wont come out, you need to replace the power supply. hope it helps. good day.
Jan 07, 2010 | Dell OptiPlex SX280 PC Desktop
Wont start up
We will see if the problem is due to the static charge accumulated on the laptop. Disconnect the power cable from the laptop and also take out the battery. Also, disconnect all the external devices attached to the laptop e.g. external mouse, keyboard, printer. Now keep on holding down the power button on the laptop for the next 30 seconds. Put the battery back and plug the power cable. Now try turning on the laptop and let me know if it works. Thanks!
Jan 04, 2010 | Dell XPS M1530 Laptop
Amber light blinking,replaced popwer supply ,still blinking amber
press and hold power button it is in hibernation mode when light is blinking power button is a momentary type of switch...
Dec 05, 2009 | Dell XPS 400 PC Desktop
Tower Will not turn on.
Blinking yellow/amber light indicates PS not operating within specs. You can look at replacing the PS but might need to find out if something else caused the PS problem, such as other components caused the PS to overheat, etc. Were you having any problems with any of the drives? Strange noises etc?
Aug 04, 2008 | Dell XPS 200 PC Desktop
XPS 200 power problem
Its is probably in hibernation mode. Hold the power button in for about five seconds or more until the lights go out and the restart.
May 09, 2008 | Dell XPS 200 PC Desktop
Dell XPS 200 PC Desktop Logo
994 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
