Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Side by side..fridge is freezing up while freezer works fine
Model #51569103
worked fine till  move now fridge side freezes everthing even on the 0 setting,  freezer is working fine other than needs to be leveled
Your baffle that controls the freezer temperature is possibly broken.  If you take the cover off the dials labeled "refrigerator/freezer" the baffle is a plastic arm that controls the amount of air circulation between the freezer and the refigerator. If the arm is broken is will stay closed completely blocking the air hole or vent.  I just wedged a small piece of wood or shim in mine and it hasn't frozen up since.
Good Luck.  I know how frustrating it can be to repeatedly defrost the ice build-up.
Mary Lynn, Alabama
Posted on Oct 21, 2007
SOURCE:
Freezer works not fridge
move the temp sensor see side of inside of fridge
Jun 24, 2013 | Dometic RM2652 Refrigerator
Freezer is at 0 degrees and my fridge is at 60 degrees
Keep 3 to 5 degree temp setting. And check defrost cycling is properly done. Due to frosting formed behind the freezer could restrict the function freezer fan which throw freeze air to refrigerant compartment. Unplug fridge till defrosting all frosting, and then plug it again. Thanks.
Feb 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer working fine, Fridge is freezing everything on low settin
THERMOSTAT ON 90% OF SIDE/SIDE REFRIGERATOR IS LOCATED AT THE TOP OF THE FRIG COMPARTMENT .YOU KNOW, THE ONE THAT HAS OFF ON IT AND USUALLY NUMBERS. YOU WILL HAVE TO DROP THE PANEL TO ACCESS THE THERMOSTAT. ALSO NOTE THAT AN INDICATION OF A STUCK THERMOSTAT IS WHEN THE COMPRESSOR RUNS AND RUNS AND DOESN'T SHUT OFF.ALSO CHECK FREEZER TEMP TO SEE IF IT IS BELOW 0 DEGREES THAT ALSO INDICATES STUCK THERMOSTAT.
Jul 25, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Fridge is freezing food on upper shelves
Either damper assembly between fridge and freezer is not working correctly or the thermostat is bad
Sep 05, 2017 | Frigidaire FRS26H5AS Side by Side...
Hi I have a whirlpool (IKEA) CBI 651 fridge/freezer, the condensation drain on the back wall of the fridge part is not draining away the water. Have tried to clean it out with red 'widget' supplied with no...
Try pouring some boiling hot water down the drain. If anything blocks the drain even slightly it will slow down the water and then freeze it. Air temp in the freezer is 0 degrees or close to that. That small of a hole it freezes quick. I'm not sure of the style of fridge this is. Side by side or top mount freezer. You are able to get to all drain pipes. If not boiling water. A hand steamer works great too.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
Jan 20, 2018 | Whirlpool Refrigerators
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
128 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
