Question about Electrical Supplies
Don't know how to find code
I'm just installing a Leviton HXC7S-1TW seven scene controller along with about 8 HCM-10 dimmers and I read the instructions but I don't know how to set the codes...where do you get the codes there not on the dimmers so how do you determin these codes from each dimmer????Berny
    Problem Solver:
  • 19 Answers
You should have a tech number to Leviton on your instalation instruction.
Posted on May 10, 2009
Why do dimmer light switches run hot to the touch?
Dimmer should be warm... but never HOT
7 x 65 = 455 watt
Dimmers are rated 600 watt to 1500 watt
Sounds like you have bad dimmer.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
Gene
Oct 07, 2014 | Leviton Electrical Supplies
Leviton switches getting hot
Sounds as if there is to many watts going trough switch . Make sure it is rated for the lighting load.
Jun 12, 2014 | Leviton VRS05-1LZ Vizia RF 5A Incandescent...
HXC1D-1TW not working
The module if failed is either open circuit or short circuit. Being that it is a semiconductor you can test each leg for one or the other. If you had the numbers written on the component we could have checked a cross reference book for the type of semiconductor. It may be a mosfet (metal oxide semi-conductor field effect transistor). How to test a mosfet youtube video The rest of your dimmer is a variable resister or potentiometer or rheostat. You can test that for a failure with a multimeter in the ohms setting, though it is less likely to fail that the mosfet.
Nov 20, 2013 | Leviton Dhc Dimmer - HXC1D-1TW - Alabaster
Leviton dimmer
Your product is not identified by number given.
Leviton posts manuals online by searching Leviton xxxx .pdf.
There is a CPT 602 lighting console
However no result shows online or at Leviton for a 602 dimmer
Contact Leviton:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37579&minisite=10251
Add a comment and attach photo or video for possible identification
May 27, 2013 | Leviton Electrical Supplies
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
Sep 11, 2011 | Electrical Supplies
How do i program the LEVITON Decora Timer Light Switch 10/24hrs.
From this website you can download a free instruction sheet in PDF format...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=6216&section=17138
May 12, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
On/off works but dimmers do not. leviton toggle
If each pendant has an individual transformer that is about the size of a hotwheel then you need a dimmer specifically for ELECTRONIC LOW VOLTAGE. A lot of electricians don't know that the different types of lights require different dimmers. Most store bought dimmers are for incandescent lights only, and some nicer dimmers like the Lutron Maestro's are rated for incandescent or MAGNETIC Low Voltage which require a different Sin wave interuption. I don't know that leviton makes a dimmer in that style for Electronic Low Voltage. You could install a Lutron DVELV300P-Wh, but that is a Decora opening. http://www.lutron.com/CMS400/WorkArea/downloadasset.aspx?id=25437
Here is a link to explain the difference in how the dimmer needs to work. Good luck!
Mar 03, 2010 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Oct 10, 2009 | Leviton Decora Light Dimmer Switch
Electrical Supplies Logo
91 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
