Question about Gateway DC-M40 Digital Camera
Batteries I have a Gateway DC-M40 camera. The batteries drain very fast and the situation keeps on getting worse. Yesterday I loaded a fresh set of batteries & they drained to 25% within hours & I had not taken a single picture & the camera was OFF all trhe time.
    Problem Solver:
  • 10 Answers
Regular alkaline batteries do not last very long in this camera due to the high current demands of the flash. I recommend using either the Energizer lithium batteries or a type labeled specifically for digital cameras. Yes they cost more, but will last much longer.
Posted on Jan 05, 2009
USE LITHIUM BATTERIES
Posted on Jun 02, 2008
Why are the batteries dying so quickly in my Kodak 12MP?
It depends, if you are using regular Alkaline batteries, those are known to go dead really fast. Better if you try some rechargeable batteries with a rating of at least 2100mAh, anything smaller than that will drain just as quick as Alkalines.
Feb 28, 2015 | Kodak Easyshare C182 12MP Digital Camera
FORMAT ERROR shows up in the window. Cannot take pictures, or review shots. Gateway DC-T50 Digital Camera The problem occurred after I tried to hook it up to my Mac computer to download pictures which I...
Remove the batteries wait a few minutes. Put fresh batteries back in and turn the camera on. This resets the camera.Then remove the memory card from the slot from your camera. Then insert back and check you will not be getting this error.
If still there is some problem, take the memory card out and copy the pictures from the memory card to system and then format it. Insert the card back to the camera. You won't get the format error.
Hope this helps.
If you still have any queries feel free to ask us.
Shane
Feb 18, 2011 | Gateway DC-T50 Digital Camera
Where can i buy cf card for gateway dc-m40 digital camera?
You should be able to buy CF cards at just about any camera, department, electronics, or office-supply store. Some drugstores and supermarkets carry them as well.
Feb 12, 2011 | Gateway DC-M40 Digital Camera
Hi, my olympus digital camera FE-310 (1,6 years old) often indicates immediately 'battery empty' even with fresh batteries. I tried out different kinds of batteries, but the problem seems to get worse...
Make sure you have the right kind of batteries. These kinds of cameras can use the batteries very fast if they are not the correct kind recommended by the user manual. Read the user manual.
If the camera works correctly, and takes pictures and movies okay, and still uses batteries quickly, then more than likely, the batteries must be the wrong kind. Never use the cheapest kind of double-A in these cameras.
If you use rechargeable batteries, make sure they are charged fully before using the camera.
Try this: Turn the camera on, make sure that the menu setting for the kind of batteries you have installed is set correctly. If you set the wrong kind of batteries, the problems you are having is a common thing.
Also turn the camera on, then set all the menus to the default settings. Then make sure that the kind of batteries you are using is set in the menu as (if alkaline set it so... If rechargeable, set so ... other options may exist in menus).
Oct 23, 2009 | Cameras
Samsung S1065 beeps 3 times and nothing else
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 11, 2009 | Gateway DC-M40 Digital Camera
Samsung s1065 beeps 3 times nothing else. only 6months old wont turn on. bought recommended batteries, still wont turn on
One of the 4 conditions a-batteries are inserted incorrectly b-batteries have died and need to be replaced c-you have selected the wrong battery type option on the Setup2 menu d-your camera is malfunctioning and needs servicing.
Jul 19, 2009 | Gateway DC-M40 Digital Camera
S1065 BEEPS 3 TIMES THEN NOTHING
IT USUALLY DOES THAT WHEN THE BATTERIES ARE DYING AND IT SHUTS DOWN - HAVE YOU TRIED USING RECHAREGABLE BATTERIES - THEY LAST A LITTLE LONGER.
Jun 13, 2009 | Gateway DC-M40 Digital Camera
Shut down prematurely
It turns out that the problem was the batteries. I put some good ones that I had in the camera and it started working just fine. Even though the others were showing that they at least partially working, maybe just not enough juice to really work. Anyway, with just about any problem - try new batteries first and see if there is any change or improvement.
Sep 10, 2008 | Gateway DC-M40 Digital Camera
Gateway DC-M40 Digital Camera Logo
80 people viewed this question
Top Gateway Cameras Experts
Steve
mohamed salim shaikh
micky dee
Are you a Gateway Camera Expert? Answer questions, earn points and help others
