Question about Sharp AR-207 Copier
Sharp copier broken
When we turn on the machine or when we send a page through the feeder, there is a machine gun sound.. how can we fix this?
    Problem Solver:
  • 6 Answers
Your waste toner is full empty it there is a screw mechanism that feeds waste toner into the waste it makes a racket as it is blocked as the toner can go nowhere you may also be low on toner
Posted on Dec 04, 2007
Your out of toner
Posted on Oct 18, 2007
  • 69 Answers
Hi im jules_09.chech the feeder,there must be somethung with the rollers specially the rubber ones,then check all bushing of each roller.some times bushing gets cranky also checki the gear that help the feeder run thwe paper when in gears are deffective or rollers they make a un ussuall sound
Posted on Oct 12, 2007
SOURCE:
How to clean my sharp ar153 copier? it produces thin black line
Is this thin line being produce when you send the original thur the document feeder?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 02, 2014 | Sharp AR-153E Toner Cartridge AR153E...
I need document feeder tray & document feeder unit for Sharp AR507
The RSPF (Reversing Single Page Feed) document feeder unit doesn't have a single part designation for ordering the entire unit. It's a standard item with the AR507 (meaning it's considered a part of the full machine).
If you want to order individual parts of the document feeder, you can contact Sharp via their website.
Sep 15, 2009 | Sharp Office Equipment & Supplies
Auto feeder not working
Easy fix. Turn the machine off, on the back side of the document feeder is one beige cable. Unscrew the two screws and disconnect the cable. Turn the machine on with the feeder unplugged, let it come to ready. turn the machine off, connect the beige connector and turn the machine back on, It basically forgot it has a feeder and needs to plug and play without the feeder then to detect it when plugged back in,
Aug 13, 2009 | Xerox CopyCentre C20 Black and White...
Sharp ARM450-2nd page 50% lighter
Hi, The M-450 uses two different methods of scanning, 1 for the front and a second for the back. these can be cleaned and adjusted individually.
Make sure both glasses are clean and free from paper dust. If you open the doc feeder and find the two small **** glasses one is attached to the underside of the doc feeder.
Also the machine may need a good servicing with the supplies (Drum, Drum Blade, Developer...) being changed and calibrated.
I know this is a lot of info but there is a lot going on with this machine.
Hope that helps.
Lbcoaster
Jul 13, 2009 | Sharp Office Equipment & Supplies
Forgot how to send a Fax
Place your document(s) face down in the feeder, dial number, and press "start". That's it.
*Please rate me
Mar 26, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Scanning documents
Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
Thanks J
Jan 24, 2008 | Sharp AL-1551 Laser Printer
Please Help -- Erroneous Lines from Auto-Paper-Feeder
Not familiar with this particular machine, but it sounds like one which uses a seperate scanner when drawing originals from the sheet feeder. Have a look to see if there's a glass strip to the side of the main copier face. If so, give that a careful clean. A.
Apr 04, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Auto feeder misalignment
Are you sure you don't have a static problem locking the paper to the glass.
Mar 29, 2007 | Sharp AL 1631 Copier
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Sharp AR-207 Copier Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
