My olympas c-211 says card errow can i format the card if so how
Be careful!
• This operation will destroy all data in the card. If you have already used the card, be sure that you are not about to destroy important image data.
• Some cards come equipped with special built-in functions. Formatting such cards may in some cases cause them to loose their functionality. Before formatting a specialty card, please read the documentation included with the card.
• You cannot format a card that is protected by a write-protect seal.You must remove the seal before formatting. Please discard used seals; write-protect seals should not be reused.
Go to Menu and select the trashcan. Select the symbol that looks like a hammer. Select Yes or No.
CAUTION
• You cannot cancel formatting once the camera has begun executing the format. After selecting YES and pressing the OK button, you must allow formatting to proceed.
• Do not open the card compartment cover, remove the batteries, or disconnect the AC adapter while formatting is in progress (while the lamp is blinking), as doing so may damage the card.
