Question about Panasonic CW-C101MU Air Conditioner
Can coolant be added to Panasonic AC CW-C101MU? Instruction plz.
When turned on fan works, but air is not being cooled. Filter and inside has been cleaned.
  • 121 Answers
This can be done if your a good hand at soldering. You need to put a inlet valve in the unit so you can put freon in this is kind of a tricky job most of the time it's easier to take it to the repair shop and let them put the valve on then after that you can recharge the freon on your own..........I hope this was helpful...... : )
Posted on May 09, 2009
97 mazda b2300 air compesser clulch not kickin on but cool air works not on max work cool on a/c
coolant temp rising indicates a faulty viscous fan hub
if turning the ac on cools it a bit that is because the ac fan for the condenser is moving air through the radiator and assisting the engine fan
Jun 25, 2015 | Mazda Cars & Trucks
My 98 pontiac grandam bogs out and tries to die
the idle up solenoid may be disconnected it is usually a vaccume hose that detects extra load when ac is on and slightly raises idle . however the over heating issue is a concern . check that the radiator has coolant and all air is blead from the coolant system, check that the electric cooling fans are operational and they should come on regardless of the eng temp if ac is on. if fans are not working check coolant fan fuses
Sep 05, 2014 | Cars & Trucks
1999 Olds Alero 4 cyl running hotter than normal. One mechanic says it's Heat sensor that opens and closes. The other mechanic who ran car says it was thermostat that turns on dual fans. Ok well one was...
REPLACE THERMOSTAT.ITS STICKING CLOSE TO KEEP COOLANT FROM CIRCULATING THROUGH ENGINE AND RADIATOR. THE FANS SHOULD COME ON WHEN VECHICLE SETTING AT A LONG IDLE.THE COOLANT TEMPERATURE SENSOR GET TO CERTAIN TEMPERATURE WHICH WILL COMPLETE CIRCUIT PCM SEND POWER TO COOLANT SENSOR THEN TO COOLANT FANS RELAYS AND FANS.IF VECHICLE OVER HEATING WHILE MOVING THERMOSTAT FAULTY.IF YOU TURN AC AND COOLANT FANS DONT RUN CHECK COOLANT FANS FUSE AND RELAY.IF COOLING FANS DONT TURN ON WITH AIR CONDITIONER ON EITHER COOLANT TEMPERATURE SENSOR FAULTY OR PCM FAULTY.IF ALL LOOKS GOOD.IF ENGINE OIL LOOKS LIKE MILK SHAKE.YOU HAVE BLOWN HEAD GASKET.
Nov 11, 2010 | 1999 Oldsmobile Alero
Compressor does not come on. I hear a short buzz like something wants to switch on.
you can try to replace the capacitor of the compressor, if the problem still the same, the damage caused by the electricity circuit and its temperature control. check the thermostat, and main kontrol.
Oct 19, 2010 | Panasonic CW-C101MU Air Conditioner
I have an old CW-C60YU model air conditioner which is in one of my walls. How do I remove the chassis in order to check for mold? I have removed the filter as well as several screws but it still does not...
I believer to panasonic does not pull out but you have to take the unit apart by taking it out of the wall and removing a screw on top (or more) and all of the screws around the bottom edge. It has been a number of years since I worked on a panasonic but if there are screws around the bottom this is usually a sign its a cased model and not a slide out. But on the mold if you have any it will be on the inside coil only if you see no visible mold you have none. If you want to kill mold spores mix a 10% solution of bleach in a spray bottle and spray the inside coil with the unit off ketch any drips and then hold a towel ect you dont like over the front and turn on the fan (no need for cool just fan) Shut it off and repeat. Then let it set for 10 min and then spray with clean water just like the bleach but do it 3 times. This will kill any mold in your tray or backside of the coils. I hope this helps just becareful with the bleach it is very uncomfortable in the eyes only happened to me once never again. good luck
Aug 16, 2010 | Panasonic CW-C60RU Air Conditioner
How much coolant do I add to top up if warning light comes on
NEVER OPEN THE COOLANT RESERVOIR WHEN THE ENGINE IS HOT!!!
If the coolant level gets too low, the air gets inside the cooling system and there's no proper circulation. Here's how you can fix it yourself: turn the heater on maximum temperature (inside the car), then start adding BMW coolant (it has to be the BMW coolant) to the overflow tank -cooling reservoir. Some models have a bleeder on the upper radiator house, so you have to loose the bleeder. The fluid will push the air out- also there may be a little of coolant coming out, which is O.K..
Next, tighten the bleeder after the coolant reaches the maximum level,close the reservoir and start the engine and wait till it warms up to the normal operating temperature or in other words, when the cooling fan (the fan is just behind the radiator) turns on and off. One more thing, there should be hot air blowing out of the heater inside your car. If it blows cold air, there's still some air in the cooling system and you should see a mechanic.If you don't, you might over-heat the engine.
Jan 30, 2010 | 2001 BMW 330
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
Help!!!!!!!! could die if u dont!!!!!!!!
Hello. Maybe you have a magnetized display. To get rid of that, plug your tv out from the mains and find a soldering gun (those used by electronics guys). Place the lateral of the gun near on the front of the display (touching the glass) press the button and slowly move the soldering gun around all the surface of the display. Carefull not to touch anything or yourself with the tip of the gun, it get's hot. Do this for about 2 minutes. Then power back the tv and check if something is different.
Feb 26, 2007 | Panasonic CW-C101MU Air Conditioner
Compressor hesitancy
Possible run capacitor fault. Call a repairman.
Feb 01, 2007 | Panasonic CW-C101MU Air Conditioner
Panasonic CW-C101MU Air Conditioner Logo
270 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
