Have echo and new apple i pad how do i install it to get wifi. i have 0 knowlwdge
Follow the small sheet of instructions that came with the ECHO.
if you want to hear music (and other audio) in stereo, attach a separate pair of stereo speakers to the 3.5 mm jack on the back of the ECHO (I'm assuming it has one like my Echo Dot does).
you may have to push the 3.5 mm plug in hard for it to connect to both stereo channels on the cable. If you only hear sound out of your left speaker, both channels aren't connecting. Disconnect and reconnect the 3.5 mm cable a few times, being sure to push it in hard. This will loosen up the jack so that the plug connects easier and correctly.
On your iPad, open the App Store by tapping its icon.
in the search box at the top, type Alexa.
From the list provided, click the Open button next to the icon for Amazon Alexa, and follow any instructions that may follow. The icon should appear on you iPad, most likely on the last screen of icons (assuming the you have more than one screen of icons). Sweep to the left until you get to the last screen of icons to see it. Then click on the icon to open the app. When the app opens, click on the "3 horizontal bar" icon in the upper left corner. A menu will drop down. Click Settings. Then, click SET UP A NEW DEVICE , and follow the instructions.
