Question about Philips gemini TT-02 MK2 Turntable
Belt drive replacement B&O Beogram 1000, type 5203 turntable
I need to know:
Round belt lenght
To take off plate record shaft, must I drill off 3 rivets underside or to knock out a lock pin?
thanks a lot
  • 122 Answers
Length approx 30mm shorter than old one, knock out pin on shaft to take platter off.more often than not the motor runs slow after repair,if its a round style ac motor htey cant be fixed.
Posted on Jan 11, 2010
I have a Bang&Olufsen Beogram
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Jul 08, 2008 | Audio Players & Recorders
Beogram 1100 not turning
If your platter runs off of a belt then the belt would need to be replaced after many years especially if its been in storage. Another thing is, if you can see the motor with the flywheel on it, it is a good idea to spray just a little WD-40 down the shaft to free up the motor and just let it run for several hours after the table was sitting dormant for so long.
Apr 26, 2014 | Audio Players & Recorders
I just bought a aiwa turntable & stereo at yard sale. the old lady said she never used it but yet the turntable will not turn. i've looked over the manual and can't find any troubleshooting. can you...
Hi Denise, I am in the consumer electronics repair industry. It may be as simple as this... Lift up the MAT on the turn table. This is the black rubber covering that you place the record on. Look through the holes in the plastic turntable (rotate if necessary) until you see the motor/pulley shaft sticking up (brass color). The turntable belt may have dislodged from this pulley. If you see the black flat rubber belt near here, just put it around the pulley again. Make sure it is not twisted and sits flat. Spin table by hand to be sure it is seated properly.
Now you may have to remove the plastic turntable itself if you can't see the belt right away. In this case, remove the C-clip with a flat screwdriver (be sure not to lose it) from the record center post. Lift the turntable plate up shaft. Check to see if the belt is still partially around the plate. You may be able to just see enough to wrap the belt around the motor pulley now. If you need to take the plate off completely, then just place the belt first around the groove on the plate and finese the belt around the motor pulley. Now seat the plate, replace the C-clip and place the MAT back on and it should be good to go.
I had this same problem on a new turntable I got for free. Good luck : )
Oct 17, 2010 | Audio Players & Recorders
The drive belt off my AWA turntable has come off and I cannot re-configure it
undo clip on centre of deck circlip normally (round clip) remove deck platter round plastic that records sit on...when removed turn over replace drive belt if brokern . if just come of place belt around the inner circle so there are no twists etc on the belt ....look at near outer edge of platter there is a clip you can stretch belt to to hold so you can put over drive motor...(belt stretch from centre to clip creating v with the bely as you veiw from above ..locate motor on the deck noe alifn top of v with positin above motor .. when done drop down platter onto centre shaft again.gently turn the platter clock wise until belt locates correctly with deck ..replace clip and test ..if ok done ..if not repeat until you get it right....sometimes over time belts stretch so a new belt may be required ..ebay can supply most belts . type in turntable drive belt ..measur size of belt by cutting is it..(if strectched and no use) measure lenght of belt find replacement belt that is smaller than measurment .i.e nearest size ...hope this helps yammandan
Aug 19, 2010 | Audio Players & Recorders
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
knock pin out.make sure idler assy moves freely away from motor shaft.
May 09, 2009 | Philips gemini TT-02 MK2 Turntable
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
7) That's it.
- OPTiC
MasterTech
Feb 28, 2009 | Technics SL-BD22 Turntable
The belt on my turn table came lose
01- Remove the rubber cushion.
02- Remove the Turntable Platter
03- Place your drive belt around the ridge inside the platter
(Make sure that it is not twisted)
04-Place your Turntable Platter back on the unit
05-rotate your platter until you can see a brass knob through one of the round holes in the turntable. (Your belt must be placed around the brass knob) The best way is to take a toothpick and carefully slide it under the drive belt and then pull it out enough that you can place it around the knob. I had the same problem and the above works. If you still have problems getting it back on contact me 352-377-1828......
May 03, 2008 | Teac P-A688 Turntable
Turntable drive belt replacement
7) That's it.
- OPTiC
MasterTech
Nov 27, 2007 | GPX S7799 Shelf System
Philips gemini  TT-02 MK2 Turntable Logo
1,175 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
