Question about RCA 32F531T 32" TV
Rca f27450 TV
TV turned on just fine. last couple weeks it would turn it self off then back on again. now it turned itself off and will not turn back on. it is humming as if it is trying to do something. unplugged for now.
  • korea Nov 20, 2007
    RCA 27" less than 2 years old. Turns on and off by itself. Sometimes stays on for an hour then starts again.
  • blacberrie Nov 21, 2007
    The TV was working fine now it is controling itself. Changing channels, turing the volume up and down, will not all remote control to control the TV. Cannot turn off unless the Tv is unplugged.
It sound like your set have dryjoints
Posted on Oct 27, 2007
SOURCE:
Tv wont stay on whats broke in it
if it turns off in the same amount of time every time, and can turn right back on, check your sleep settings... it is a feature that turns the tv off for you.
Mar 05, 2014 | RCA F27450 27" TV
Rca flat panel tv turns itself off. LED light on pwer button blinks 3 times,but wont turn back on
With the model which is not indicated here Google that for 3 blinks to know what the error code means.
Dec 23, 2012 | RCA Televison & Video
We have a Sony rear projection TV (model KP/FX432M31) - it wont stay on. sure it is a timing issue as it will turn on at odd times all by itself but once we have turned it off we can not turn it back on...
The problem on your tv is the leaky electroltytic capacitor on the regulator section.
Replaced the capacitor on that area and your unit will be back to normal again.
If you don't have an experience in electronics find a qualified technician to do the job for you.
Have a nice day!
Thanks for using fixya.
JDVillanueva
Feb 03, 2011 | RCA F27450 27" TV
MY R.C.A. MODEL 20F420T WILL NOT STAY ON. TURN IT ON IT MAY STAY ON 3 SECONDS TURNS IT SELF OFF TRY AGAIN IT MAY STAY ON 2 SECONDS BACK OFF THANK YOU ????
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down. Either a major component in the horizontal section has failed or the main power supply itself is defective.
Dec 05, 2010 | RCA 20F420T 20" TV
TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Sep 07, 2009 | RCA 36V430T 36" TV
RCA 46'' rear projection TV, dated 1998 won't turn on
Probably a new problem given the age of the TV. If you already haven't done so, try unplugging the power for about 10 minutes, plug back in and try again.
Jul 07, 2009 | Televison & Video
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
Good day.
Your problem points out to the TAC switches of your unit. Better have those pulled out and be replaced.
Regards,
chris
Jul 31, 2008 | RCA F27450 27" TV
Picture size
I called RCA about this and first was told that it was my cable company till I told the rep that it does this even when I unhook the cable. I was then told that I could take it in to get it fixed and that even it it was a bad part on their end that I could end up paying for it as if might be the pictue tube or the screen. Guess this will be the last RCA that I ever buy again.
Oct 22, 2007 | RCA F27450 27" TV
Tv keeps turning itself off
you must contact service bycouse you need the asistance
May 25, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
RCA 32F531T 32" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
