I just got this washing machine today and it dont seam to agitate real fast.. is this normal?
  • 10,865 Answers
Yes. new models are more green tnan the older ones. they use less water and less power. Better engineering allows to happen.
Posted on May 09, 2009
  • 11,896 Answers
Some of the newer washer have a more gentle agitation. Make sure it is set on the highest settings for regular agiation. Cottons and all other like super wash, any high settings. Most the newer washer are like this to preserve energy.
I have a NEW Roper Washer. It agitates somewhat slowly. My old washer agitated FAST. Is this normal for a Roper?
I would have a look at the cam dogs located in the agitator and the motor coupler or belt if not direct drive. check for loose clutch or slipping tranny. also check for worn agitator spline
agitator coupler bell housing removewasher101-r0vmhnqx3ofapyttmvvmotan-4-9.jpg
Apr 15, 2017 | Roper Washing Machines
Removing kenmore agitator 417.94862302
You do not have agitator dogs in your machine, yours is made by Frigidaire the agitator can be removed by removing the top of the agitator and remove the bolt. It is screwed directly into the transmission shaft, You want to check the belt to see if it is stretch out , just normal from use.
Feb 06, 2014 | Kenmore 24032\24036 Top Load Washer
Whirlpool 8100 series Top loader;the centre piece will not operate. so it will not turn or spin. everything else seams ok. It seams like the centre section is somehow disconnected?
hello it sounds like the agitator dogs are bad part # 80040 pop thecenter cap off there is a center bolt holding it down the dogs are inside the agitator these should fix your problem if its the top half not moving. if the bottom isnt moving look at the under side of it when you take it oss see if it is damaged. if its not damaged and the bottom half dont move on agitate it could be the trans. please dont forget to rate my answer thank you.
Jun 08, 2011 | Washing Machines
Have a Sears 110 topload washer, it fills, agitates for appx 10 seconds, stops,wait for a few minutes, agitates again for a few seconds and stops. ??
this sounds ilke its in a delicate cycle or fabric care cycle...did you try putting this in normal or regular wash are the speed selectors set to fast/fast...let me know if this does not help...
Jan 23, 2011 | Kenmore Washing Machines
I have a GE clothes washer, model# WKRE6280D0WW, and the agitator has stopped working. It just spins freely in the drum. The wash setting has always been on normal/fast, but a few days ago, I set it to...
What you have is a bad drive block. Grab the agitator and snatch it off. The block is bolted to the tranny.
54b9ead.jpgWH43X10009 is the part number. Not very expensive nor hard to replace. the agitator snaps onto this block. The block is plastic andit has splines in it. they wear down smooth and cause the washer to do just what you describe.Read more
Mar 07, 2009 | Washing Machines
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
