Question about Garden
Won't stay running after 5 minutes of using it
Husqvarna 41 so t stay running after 5 minutes of using it
  • Anonymous May 10, 2009
    I was told by Sears Parts & Service that my MAC3200 needs a new carb and they can't get the part! It quits running after 5-10 min.
    Sergeant:
  • 384 Answers
Try to adjust the HI LOW screws on side of carb .turn low out a1/4 to 1/2 turn to start good luck
Posted on May 13, 2009
I have a husqvarna push mower that starts up for 2 seconds then dies i can,t figure out the problem i changed the gaskets on the carburter it won,t stay running does anyone have any solutions
carburetor is dirty. take it apart and clean it with carburetor cleaner and put a new needle and seat in it. its cheap to do and will make it run like new
Jun 18, 2017 | Husqvarna Garden
Can I take piston and rings out of a 41 husqvarna and put it in. a husqvarna 350 chainsaw
No. The 41 uses a 40 mm piston and the 350 uses a 44mm piston.
Mar 21, 2015 | Husqvarna Garden
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
22 hp b/s won't stay running
check spark make sure its bright blue but sounds like a dirty carb needle valve isnt opening enough not letting enough fuel in
Jun 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Husqvarna riding lawn mower yth 2448 cuts off as if running out of gas after 10 - 30 minutes
Mine would run for about 15 minutes and die. I pulled the carb off and thoroughly cleaned it. Inside the float bowl there is a plastic device held on by two phillips headed screws. Under this device are two tiny tubes with small holes in the side of them. Make sure these are clean. I used carb cleaner in a spray can and a tip cleaner. Make sure to wear eye protection if you use spray cleaner. I reinstalled the carb and, so far, it is working fine.
Apr 08, 2012 | Husqvarna Garden
My husqvarna 61 inch lawn mower will not stay running
Did you check the oil? Some engines have a low oil shut off switch to prevent the engine from running out of oil and burning themselves up. If it is low in oil and all the oil is up in the engine to lubricate, then the switch may be setting itself off. After a few minutes, the oil comes back down to satisfy the switch and it starts back up, but only till the switch is activated again. Might do it???
Dec 27, 2011 | Husqvarna Garden
Husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Model 41 - Chain slips when cutting. Is there a clutch adjustment or does it need replaced.
No adjustment, it must be replaced. A Husqvarna 41 (1997-07) example IPL follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/1997/I97000/I9701030.PDF
Detail H: pn 530 09 41-88 contains the clutch face. Please carefully inspect the clutch drum (cracks and glaze) pn 530 03 21-19 bearing should probably be replaced too.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 20, 2010 | Husqvarna Garden
Garden Logo
220 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
