Question about Philips gemini TT-02 MK2 Turntable
Belt drive replacement
I keep a B&O Beogram 1000, type 5203 turntable after many years
3 questions
-No service manual, I have one concerning type 5229 only
-Belt jumped off the plate grove I'm not sure it is good condition; round profile but I know nothing on original lenght
-I open turntable and for take off the plate shaft 'm not sure if needing to drill out 3 rivets or if enough to knock out a lock pin
thanks support
Fernando
  • 122 Answers
Knock pin out.make sure idler assy moves freely away from motor shaft.
Posted on Jan 11, 2010
My Beogram 1202 won't work with my beocenter 9300. Both work fine by themselves . Ie the phono input on the 9300 works with other equipment. And the Beograd works when plugged into a different amp
When you say that your 9300 "works with other equipment", does that include another turntable? If not, that is worth testing.
Over the last several years, most receivers have "lost" the ability to use phono inputs directly, and may need a 'pre-amp" module to do so.
Jun 02, 2016 | Audio Players & Recorders
I have a Bang&Olufsen Beogram
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Jul 08, 2008 | Audio Players & Recorders
Why did it stop revolving?
The driving element, be it belt or rubber puck, may have failed. It's not an unusual failure in a turntable that is several years old and rarely used.
Jan 08, 2016 | Audio Players & Recorders
Beogram 1100 not turning
If your platter runs off of a belt then the belt would need to be replaced after many years especially if its been in storage. Another thing is, if you can see the motor with the flywheel on it, it is a good idea to spray just a little WD-40 down the shaft to free up the motor and just let it run for several hours after the table was sitting dormant for so long.
Apr 26, 2014 | Audio Players & Recorders
What type of maintenance my car would need after 90,000 miles
There is no special service needed at 90,000 miles other than the normal Air Filter & Cabin Filter replacement every 30,000 miles. Inspect all drive belts and hoses. You do need to replace Brake Fluid every 3 years independent of mileage. At 110,000 miles replace the spark plugs on a 4 cylinder, 105,000 on a V6. Replace engine coolant at 120,000 or 10 years on both engines. Replace A/T fluid at 60,000 miles. On the V6 at 105,000 miles replace the Cam belt and Water Pump. The 4 cylinder has a chain that you replace when it is noisy or you cannot keep the engine in time.
Oct 30, 2009 | 2004 Chevrolet Malibu
Bang and Olufsen Turntable will not platter will not spin
Normally on the RX-2 there are only 3 transit screws but if they are stuck you might need to gently try to lift them while turning anti clockwise. You can do this with a Steel Ruler and yoiu may have to use a little bit of force as some people torque them down tight. As for manuals and service manuals - they are rare!
Oct 07, 2009 | Audio Players & Recorders
Belt drive replacement B&O Beogram 1000, type 5203 turntable
length approx 30mm shorter than old one, knock out pin on shaft to take platter off.more often than not the motor runs slow after repair,if its a round style ac motor htey cant be fixed.
May 09, 2009 | Philips gemini TT-02 MK2 Turntable
Turntable belt drive keeps slipping off.
I have a Linn LP12. At least in the case of my turntable, that's just how you are supposed to use it (i.e. this is what the manual says). You could get a replacement belt f you like, but I would guess it will not make a difference - that is, I think you do not need a replacement belt.
However, in my case I don't have to be very careful about the start-up push on the turntable, just one tweak to get it rotating at about the right speed is enough in my case.
Mar 10, 2009 | Thorens Audio Players & Recorders
I have a old antique wurlitzer and the records are playing very slowly what can be causing this
Bad drive belts.
Motor needs servicing (most likely).
Hasn't been converted for 50 Hz.
Dave F.
Nov 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
Belt Drive
The belt is replaced as in the following diagram from the manual that you can download on the link below: http://www.lpgear.com/at_pl50_om.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Audio Technica AT-PL50 Turntable
Philips gemini  TT-02 MK2 Turntable Logo
295 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
