Question about Troy-Bilt Garden
I have 8hp troybilt horse rototiller. when i pull the starter rope, it doesn't engage. so i took it apart and i see that the place, where there are some ball bearings that are supposed to engage and turn a large wheel to start engine, is worn. but i don't know what these parts are called to be able to look them up and i can't find any pictures of a recoil starter to help me. i want to replace the worn part.
  • bomkampc May 10, 2009
    i want to know what the part is called so i can go to a parts store and ask for one and what it is supposed to look and function like when it is in good working order so that i know if that is indeed the problem. i am not yet to the point of wanting to remove it. i really can't even describe it very well because i don't have names for any of the parts so i was hoping to find a picture of a recoil starter but when i type that into google i don't get anything but parts dealers who want to know part names and numbers
    ok thanks. i did manage to find a diagram and am starting to get an idea of what i'm dealing with
  • 11,896 Answers
The pully teeth that you are tallking about can easily be sprayed with WD-40 or equivellant. Than keep working it and it WILL eventually come loose. I have worked with small engines for 10 years. This should solve the problem
Posted on May 09, 2009
  • Nate Stansfield
    Nate Stansfield May 10, 2009
    A recoil starter mechanism (10) mounted in axial alignment with the
    flywheel (12) of an internal combustion engine has a drive plate (16)
    with clutch teeth (34) which moves axially when rotated to engage
    clutch teeth (17) on the flywheel and rotate the flywheel (12) to start
    the engine. The drive plate (16) is driven axially and rotationally by
    ramps (30) on the starter pulley (14) when the starter rope (24) is
    pulled. A brake plate (18) frictionally engaging the starter housing
    (13) has arms (37) engaging the drive plate to resist rotation of the
    drive plate (16), thereby forcing the drive plate to move axially as
    the starter pulley (14) is rotated.
Pull start not turning engine. not engaging
www.troybilt.com/equipment/troybilt/ownercenter
Take it off and you will see a pawn(s) that stick out and engages the flywheel when the rope is pulled. You will also see why that is not happening. Stuck ,broken or stripped pawn maybe.
Aug 24, 2013 | Troy-Bilt 25cc 4-Cycle Straight-Shaft Gas...
I broke th pull cord on my ryobi ss26 weed wacker.took it apart to restring is there a certain way it must go back together? does the cord through the little hole thats on the spool? if possible can i get...
There should be a hole in the pulley that holds the starter rope in the starter/recoil unit. If you have taken the machine apart to that point, yes, there is only one way to reassemble it.
You will have to wind the starter recoil without the rope installed on itabout 5-6 complete revolutions to "pre-load" tension on the spring-steel starter spring, then lock the pulley in place, insert the pull rope and tie it off so it can come back out and then release the pulley, letting it draw in the new starter cord. Make sure you have the handle installed so it will stop when it gets to the body of the engine cover.
Sep 22, 2010 | Ryobi 15" Electric Factory Reconditioned...
Doesn,t engage with engine
sounds like the dogs and or springs are worn.When you had the cover off the machine did you check that the dogs would freely move out when the rope was pulled? They some times stick and will not engage.
Dec 26, 2009 | Toro Garden
Need to replace the recoil rope and handle on a tecumseh hm80 155481 p 8hp horazontal shaft motor. never done one before so any suggestions would be great
take the 4 bolt out of the starter housing, lay on table take the old rope out. turn the center rope pulley counter clock 6 to 7 full rotation's so the center pulley hole lines up with out housing hole(steck a screw drive throw to hold pulley in places). feed the rope from outer throw the center tie off. let the pulley dr ow the rope in. pull the rope out a Little tie off to handle
Oct 08, 2009 | Yard Machines Heavy Machinery
Troybilt pony wont go into drive.
Not technically a solution, but there are Troybuilt tiller forums out there on the net. MTD bought them out some years back and some parts are still available. I had to go thru them to find a part number for a mid 80's Horse unit that had a broken drive coupling. Anyways, they have parts breakdowns and manuals on their site. And I've seen some on ebay if you need parts.
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Electric start not working 8hp.mtd. snowblower
Hi, check the starter if it's engaging too the flywheel. there is plastic molded gear on top of your starter some times gets broken.
If this doesn’t work for you please write back. Thanks,
Nov 21, 2008 | Garden
Garden Logo
549 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
