Question about Maytag MTF2156GEB Top Freezer Refrigerator
MTF2156GEB My freezer and refrigerator are not cooling as they should. The refrigerator is slightly above room temperature. The freezer only freezes food that is in the bottom drawer that slides out.
  • 1 more comment
  • cathycoleman Oct 11, 2007
    I don't hear the fan turn on when I open the freezer - After about 10 seconds I hear a noise that sounds like maybe something trying to cut on, but then it immediately stops.   There is a thick build up of frost on the back panel.
    Is this something I can do myself?
    Thanks!
  • cathycoleman Oct 12, 2007
    model # MTF2156GEB
  • seandisme Dec 16, 2008
    I have the same problem with mine . Fan used to come on with a little nudge, but now nothing.Is there a way to check to see if fan is shot without spending money for a new one if it isnt the fan?
I have the same refrigerator.It's your defrost timer . Check Marcone check to see they have a location near you .Buy the warranty with this Maytag you are going to need it . I replaced mines twice along with the fan twice and the temo switch .Check repairclinic.com also .good luck [email protected]
Posted on Feb 22, 2008
  • 473 Answers
Check to see if you hear the fan running in the freezer when you open the door.  If you don't hear it then it will need to be replaced.  This is the most common problem on this model.  Also, check to see if there is a thick frost buildup on the back panel of the freezer.  Let me know what you find before you rate this solution.
Posted on Oct 11, 2007
  • Craig Shelton
    Craig Shelton Oct 11, 2007
    If you are handy and have some basic tools then I am sure I can walk you thru it.  It has a defrost problem.  Let's start with this.  What is the entire model # from the inside of your fridge?
SOURCE:
The plastic tray at bottom in the fridge just above freezer compartment has a slight crack. Can this be repaired
Hi, they can be repaired with a plastic solvent glue usually comes in tubes. Make sure the tray is dry and at room temperature before putting the glue on. It should slightly melt the plastic and fuse it together. I would put another coat of glue on once the first coat is dry.
Dec 24, 2015 | Frigidaire Refrigerator White Fridge &...
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer is working but refrigerator part is room temperature ,not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 23, 2011 | Refrigerators
The freezer is working fine but the refrigerator is at room temperature.
heatman101
Apr 16, 2011 | Maytag 19.8 Cu. Ft. Side-by-Side...
Freezer and Fresh food section at room temperature
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | LG LFX25960ST Stainless Steel French Door...
Freezer compartment runs continuously
icemaker running continuously but producing no ice
May 03, 2009 | Maytag MTF2156GEB Top Freezer Refrigerator
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Maytag MTF2156GEB Top Freezer Refrigerator Logo
116 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
