Question about Electrical Supplies
10,000 watt generator 220 plug doesn't work
I have a 10,000 watt generator that we purchased used. I don't know the brand. It has 2-110 outlets and 1-220 outlet. Both of the 110 outlets work just fine, but the 220 doesn't work at all. What are the possible causes and what can I do to fix the problem?
  • 1 more comment
  • Anonymous Mar 14, 2014
    i need 40 amps to power my band, how does that calculate to watts for a generator
  • Anonymous Mar 16, 2014
    I have a portable generator with 110 output and want to convert to 220 what will I do
    President:
  • 1,388 Answers
Most generators have several circuits incorporated within the windings. There are usually two 115v windings, one or two windings that produce power and sensing voltage for the regulator that supplies power to the armature (produces magnetic force) and sometimes a 12v winding to supply power to charge the battery. The two 115v windings power one 115v plug each and together power the 220v plug. Each outlet has a breaker and or ground fault. Since the 115v plugs are working indicates that the 220v plug must have an open/broken wire or faulty breaker. Easy to check, however you must open cover to wiring compartment and trace wires. Should be easy fix. You do not have to start engine to find broken wire. Use ohm meter instead. With engine off, Insert probes into 115v plug and obtain ohm reading. Then insert probes into second 115v plug and obtain similar reading. Look for same reading at the 220v plug (remember 2 circuits of 115v, ground and neutral). Good luck with your repair and email if you have other question.
Posted on May 10, 2009
How is watts we use in pakistan there watts is 220
Any Generator with standard Euro plugs should work in Pakistan.
230 VAC
Apr 27, 2016 | Watts Electrical Supplies
Have a tanka-kogyo generator deg-600 with no manual. It has two plug type female outlets. can you confirm the outlet capacity.
The capacity will be on a label on the generator portion..not the engine It will say how many watts the generator will produce.
Mar 02, 2015 | Electrical Supplies
Phonic mar6 power consumption
why put a 220 circuit breaker in you electric box and get a 220 outlet plug end on it , easy to do ,
Feb 18, 2015 | Phonic Audio Players & Recorders
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Why won't my stanley 8000 generator put out power?
You have to be missing a switch to turn on the power outlets once it is running. That or a breaker needs to be turned on.
Jun 01, 2014 | Stanley Portable Generator: 8000 Running...
I have a Genarac 7500 watt portable generator. When the power cord is plugged in to 220 AC outlet on the generator and the other end is plugged into my transfer switch the power at my house appears to be...
Dear J,
I just do happen to live close to their factory.
I pass it often.
Call their factory for your answer, better to call them during business hours.
Here is their number: 1-888-436-3722
God bless your efforts.
Jun 17, 2017 | Generac 5680 GP Series GP8000 10,000 Watt...
Does it matter if use 220 or 115... looks like i have 25 amp in the box with gfi.. need connect the wire to back of the motor.. outside i have the big circular 3 pronged connection to the outlet... do i...
220 VAC is more efficient ... so there is some cost savings in the money department. Volts X amp = watts generally ... there is still a savings because you will actually consume fewer watts at 220 (watts is what you are purchasing form the power company)
Wiring depends ...you going to use 110 or 220? if 110 ... black is hot and goes to L1 ... white is nutral and goes to L1.
If 220 ... black is hot and goes to L1 - white is hot and goes to L2.
Your owner manual has a good picture and description of this.
In the plug ... 110 - neutral should go to the left slot.
Is your breaker 110 or 220 (single pole or double pole - one slot or two slots)
These voltages are not compatable!
I suggest you use this pump at 220.
Jun 04, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Welder will not power auxillary outlets
sounds like either something is shorted out or the governor is stuck. Check the governor linkage to start with and make sure it is free. Then check the push in breakers for the outlets to see if they are popped. If not the brushes or the armature could be stuck or corroded.
Mar 28, 2009 | Hobart Welders 500433 Champion? 10,000...
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Electrical Supplies Logo
716 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
