Wires were removed from start cap 3 term need to know which wire goes to which term. terms are not readable
  • 1 more comment
  • Ken Bledsoe May 11, 2010
    What color are your loose wires? Should be able to read herm fan and comm usually comm is the center one so tell me, is this on the outside unit?
  • Dennis Boxerman May 11, 2010
    Are you sure it is a start cap and not a run cap? Run caps are all metal and start caps are almost always a black plastic type (used to be called "Bake-O-Lite") Also, a model and serial would help alot.
  • JIM PHILLIPS
    JIM PHILLIPS May 11, 2010
    do you meen start capaciter............or power wire connections...???
  • 478 Answers
C to cntactor L2/or red side
fan to brown from fan
comp to compressor start term
the one lose wire is far run so goes to C with the red wire
C is the only one with two
Posted on May 10, 2009
T-103 Black, white and ground what thermals go where
You should be able to find a wiring here. Search you should have a white, red, black, wire there. hook the white to the neutral or common. then hook the black wire to term # 1 the red wire to term # 3 and then hook the load side to term 2 and 4. it should work doing this. don't forget to hook up the ground. hope this was helpful. contact me if u need more help
Feb 03, 2015 | Intermatic T103 Indoor 120-Volt 40-amp...
Which wires hook up to the solenoid on the starter on a 2000 Chevy malibu
Hi there
The wires are the big eye term on the heavy wire and all smaller wires with big eyes goes to solenoid that has the main battery lead going to it and the small push on term goes to the pin in the center of the solenoid the only push on term.
Jul 22, 2014 | Cars & Trucks
I look at the A.O. Smith Motor Master University manual and my question concerns the diagram on page 50, Single Phase Motor. In need to operate my motor with 115V and my understanding of the diagram is...
That is correct...if you have done that and still have problems post a comment that includes a description of what is happening and the motor model and serial number for further assistance.
John
Aug 25, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Simple question, Terminals on the battery are
ALL BATTERY LEADS ARE THE SAME
Red wire is Poss or the biggest term/Black wire is Neg which goes to the smallest term which is earth..
Red is Feed wire to starter motor/Alternator lights etc Black or earth wire goes to engine somewhere on bolt on the block and also a small thinner wire goes to the body any where as long as its clean and no paint. and away you go (easy)
Let me know if you have any more problems Ron
Poss is+ Neg is--
Oct 05, 2009 | 2002 Mitsubishi Eclipse
Need a wiring diagram for 5kcp39fg general electric motor
if it has a brown/purple,and black wires and is a single phase motor, the purple and black are your 2 hot phase wires, and the brown goes to the motor capacitor and on other motor cap term that goes back to the purple phase wire
Sep 26, 2009 | Heating & Cooling
Need to switch 3 pronged plug for 4 pronged but not sure which color wire gets connected where.  Other wires were not color coded.
the red and black wires go to L1 and L2 terms doesnt matter which color on which term, white wire goes to"N" neutral terminal and green wire is safety ground that can be grounded to the steel housing of unit if your feed line comes directly from your main panel,not a sub panel,some localities will allow you to tie the white neutral and green grnd wire together in the unit chk your local ordinance first
Jul 11, 2009 | Dryers
On outside compressor for whole house AC: Critters ate wires. Have Blk & Red power in from breaker. 24vac switched from thermostat. 1 contactor with 24vac coil(original). 1 Capacitor w/ 3 terms...
There should be a wiring diagram on the back of the access panel. If you can't read it, check online for model wiring diagram. Don't guess, you may cause more expensive damage.
Jun 25, 2009 | Heating & Cooling
HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Keyless remote programming insyructions
95 bonny--1-turn ign switch off 2a75c3b.jpg 2-using a fused jumper wire jumper data link connector #8 blk/wht wire to #4 blk wire (look under dash for dlc)
3-press unlock button on 1 transmitter doors should lock and unlock
4-repeat step 3 if doing more than 1 remote
5-remove fused jumper
36a8224.jpgfor the 1993 car same way except jumper term a blk/wht
term g ppl/wht
have fun
Jun 28, 2008 | 1998 Pontiac Bonneville
Bad phone connection
Usually static with loss of tone is a damaged line somewhere. The static can be caused by a loose connection as well as corroded lines. The loss of tone is usually caused by a dead short in the line. I just re wired my dads house for the same thing and eventually found where a rabbit had chewed through the insulation on a wire outside. He was having the exact same symptoms as you are. Hope this helps, and good luck
Jan 07, 2008 | Lands Phones
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
