Question about LG HBM 730 Bluetooth Headset Wireless Headset
How do you put the LG earpiece in pairing mode???
I have the HBM-730 and need to pair it to a new phone.  How do I place the earipice into pairing mode??
  • 16 more comments
  • Sexy0517 Nov 22, 2007
    When i try to pair my LG HBM-730 it asks for a PIN code and i do not know what the PIN code is???
  • Anonymous Dec 25, 2007
    how do I pair this product with my motorola Q phone?
  • Anonymous Jan 05, 2008
    how do i find my pin code
  • Anonymous Jul 09, 2008
    How do I get my lg earpeice in pairing mode?
  • Bob DB Jul 21, 2008
    Can't pair my LG HBM730 with my cell phone. A buddy gave it to me without any manual.
  • Anonymous Aug 06, 2008
    How do I pair my LG HBM-730?
  • Anonymous Aug 14, 2008
    pairing
  • santannaj Aug 22, 2008
    how do i pair this with my phone?
  • Anonymous Sep 01, 2008
  • pepp103 Sep 01, 2008
    how do you put the lg in pairing mode?
  • mbavuso Sep 09, 2008
    I can't pair LG HBM 730 with my new phone
  • ninamariet Sep 13, 2008
    cant pair it or find a password help
  • fatkat2 Oct 12, 2008
    need the code to pair.
  • ERICGREID Dec 20, 2008
    PAIRING WITH THE NEW BLACKBERRY STORM
  • izzohardman
    izzohardman Dec 21, 2008
    I need instructions on putting the LG HBM-730 headset onto my ear. What do you need to do?
    Kansas City Computerz
    [email protected]
  • Lora Henderson Dec 26, 2008
    Pairing my Lg to my new Lg Voyager
  • Anonymous Dec 27, 2008
    I DONT KNOW HOW TO P
  • Anonymous Apr 16, 2009
    My LG 2 cannot find device for pairing my Headset bluetooth plantronics 222. I've tried absolutely everything . But still cannot find device. The only option is 1. Add New Device, but when I press ok there is still 0 devices found. Very frustrating...
0000 worked great for my LG to Motorola Headset Pairing. Thanks
Mike
Posted on Mar 15, 2008
To Guest, the author of "Solution #3"
Thank you SO MUCH for your help. Solution Number 3 did it for me. Apparently I wasn't holding the center button down for long enough, I stopped when I heard the "rising 4-chimes" to indicate it was on. I held it down for longer, & it made another funky chime (along with the LED glowing SOLID red, like you mentioned).
Bottom line, my LG HBM-730 is now connected, and working great. Thanks Guest, great advice. ;)
Posted on Jun 28, 2010
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
Posted on Oct 22, 2007
Wats the mfb buttom and were is it
Posted on Dec 29, 2008
  • Anonymous Dec 29, 2008
    where you wrote hold the mfb buttom till it turns red off the power buttom i try that but it only goes from blinking blue occasionally to it going back n forth with blue blinking and red blinking so when i go to search devices it doesnt locate it can anyone help with this
Stuff it in your *** then pull it out your ear .................ha ha ********!!!!!!
Posted on Oct 23, 2008
I LOVE YOU MEN
I FIX MY PROBLEM
Posted on Oct 08, 2008
I cant find the instruction book. How do you fit the headset on your ear?
Posted on Jun 24, 2008
Weres the mfb Button
Posted on Mar 26, 2008
0000 worked great for my Musiq once I remembered to push the connect keys as well. Thanks
6ya staff
SOURCE:
Discover mode?
Start with the headset turned off. Then, press and hold the MFB for some 10 seconds, until the indicator LED is steady lit. It should be in pairing mode. Now, make your phone's bluetooth application search for new devices. After a while, the HBM-730 will appear on the screen. Select it and command it to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 13, 2010 | LG HBM 730 Bluetooth Headset Wireless...
HBM 730 Bluetooth Headset Wireless Headset: Headset was given to me a while ago and I have a n...
To put your headset in paring mode, first turn it off. Then, press and hold the PWR/END button until the indicator led is solid lit (some 5 seconds). Now, make your phone's bluetooth software to search for devices. Select 'LG HBM-730' from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Cheers! Carlos
May 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
My LG HBM-730 does not connect to cell phone
I powered down both my cell phone and bluetooth earpiece. Attempted to reconncect and it worked immediately.
Jan 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Pairing 730 and lg vx 860
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Connecting to my phone
With many phones you have to have the phone in the bluetooth search mode, before you put the headset into the pairing mode.
Aug 31, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 and VX 9400 pairing problem
I found the solution. The original password setting is a combination of zeroes - at least 4. If you did not originally change your password setting for your bluetooth from the original setting - try that. It worked for me.
Also - Thank you for your reply.
Oct 25, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM-730 disconnect problem
Check your headset on a different phone if the same thing happens - you need a new headset.
Aug 13, 2007 | LG HBM 730 Bluetooth Headset Wireless...
I can set up my headset to my new phone
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 Bluetooth Headset Wireless Headset Logo
8,465 people viewed this question
Top LG Radio Communications Experts
B.Th. Pluijm
B.Th. Pluijm
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
