Circuit breaker on treadmill trips off after 5 minutes
SOURCE: treadmill will run for about
HI, are you using an extention wire, if you are then please unroll the whole wire, another thing is you can try to put a higher amp in the plug. if after this you are still having the same problem then there is something wrong in the circuit pannel.
SOURCE: The circuit breaker trips when i get over about
hi, firstly if you are using a extention wire unroll the whole thing, and putting a higher amp volt in the plug. this should help
