Question about Craftsman Garden
I have craftsmen 5HP rear tine tiller,while tilling picked up a rock which jammed the tines and stalled the motor. when i restarted it had loud grinding noise and then locked up stopping me from being able to shift out of the till position. what should i look for? My thoughts i transmisson. thanks Ron
  • 11,896 Answers
If the tiller tines where jammed, the tranny and motor where still trying to turn and there could be a couple different parts broken. The tranny main shaft make have busted, the tranny gears could have jammed. If the motor does start, than that is a good sign. If not than the connecting rod or crank may have snapped.
I am guessing you will probably have to dismantle the transmission and see if there are any broken gears or shaft.
Posted on May 09, 2009
Tiller runs great just having a problem with the tines turning plowed my garden last week and for some reason the tines quit turning like its locked or something please help me
Two possibilities. Something has jammed the tines.
Pull the spark plug wire off and tuck it away someplace so as not to touch the plug.
Tip the tiller up and examine the tines for obstacle such as a rock. If there is nothing jammed try to turn the tines by hand. If the they turn freely you most likely broke a shear pin that secures the tines to the axle.Clean the axle and tines and examine very closely for the pin.
If sheared ( broken) you will need to drive the broken piece out and replace the pin.
There may also be a problem in the transmission case. You would need to remove the tines and case to open it
Apr 01, 2016 | Garden
My craftsman 5hp tiller hit large rock, tines stopped, loud noise followed and now pull string won't budge. Why?
most tillers are equipped with a shear pin down by the tines. for this reason. if you hit something it will shear the pin and not do damage to your machine. it don't sound like that happened here. make sure the tines are disengaged. if the rope wont pull it may have sheared the flywheel key. there are videos on you tube that will show you how to take off the cover, the flywheel and check to see if this has happened. it may have locked the engine up at the worst scenario.
Mar 30, 2016 | Craftsman Garden
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
My tiller locked up while using it. No rock is jammed.
either your motor is seized or its blown
May 26, 2009 | Garden
Breakdown of transmission on craftsmen 5HP rear tine tiller
Little grease on the shaft and some work was able to remove pulley. Found input pinion, tine sprocket and gear all missing some teeth. check with sears and these parts are no longer available. Can anyone tell me where i might find or locate replacement part i need for this tiller?
May 16, 2009 | Craftsman Garden
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
I bought my troybilt rear tine used. When I use it to till new ground (sod) it cuts fine for a few feet, then without warning, it gets on top of the ground, and I can't do anything to make it cut. The...
Hello, I think if you look at the depth setting bar you will find it clogged up with grass and roots. Once it clumps up you can't get it to drop to depth to make the cut. There are two speeds for the rear times for the toller which will make it go forward more slowly and allow the dirt clods to break up better. Also cut the grass as short as you can, make a shallow pass with the tiller 1" to 2 " to cut the heads off the roots and then go to depth with your next cut. This should pretty much break up the cloding when doing the tilling. Also watch it because it is hits a rock it will jump up and drag you away at the speed of the tines, because it lifts the drive wheels off the ground and the times drive the tiller instead. Other than that mine used to chew up everything including wet DG. Good Luck, RAC
Mar 31, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
273 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
