Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Subzero bottom freezer drawer is freezing shut.
There is a small trickle of water which appears to leak from a collection pan at the top of the freezer compartment.  The pan drains to the right of the compartment and appears to go through the wall of the freezer.  Where the pan meets the wall of the compartment it appears that the caulk has failed and the water that trickles down the inside wall of the freezer, freezes on the tracks of the drawer and makes a general mess.   Does it seem like I am going in the right direction?  Is there a special caulk to use that will not fail in the freezing temps?
  • pinebark Oct 18, 2007
    Worked......nuff said.
  • 363 Answers
Silicone bath/shower sealant should work, the one that smells like vinegar. Also known as RTV.
Just make sure the area is dry, clean and free of old caulk.
It'll need to be at room temperature to set properly for a few hours.
I have used this sealant on things before that went as low as
-50C. Preperation is the key though.
Posted on Oct 13, 2007
6ya staff
SOURCE:
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
Kenmore refrigerator
Hi David
In the freezer compartment - under the panel where the water / ice is collecting - towards the back - is a small pan. The pan collects the water when the defroster cycles on to melt ice & frost that collects on the cold coil behind the back wall panel. The pan has an opening with a small tube connected that allows the water to drain out to the larger pan on the floor under the fridge.
If the tube is clogged, the water will not drain and will eventually freeze. Every time the defrost comes on, some of this water will collect under the panel and drip into the fridge compartment if the drain remains frozen.
You will need to clear any obstruction in the drain tube with a short, flexible snake. Access it from the freezer compartment. Remove any built up ice and make sure the pan has not been bent or damaged in such a way that it will no longer allow the water to get to the drain tube. If the tube is clogged due to ice, you will have to thaw it out first. Squirt hot water down the tube to do this quickly - I used a turkey baster and towels in the freezer with excellent results. After the ice has been cleared - use the snake to make sure the tube is open. Replace / repair parts as needed.
After clearing, pour some water down the tube to check for flow. If flowing, empty the drain pan on the floor under the fridge. Next, mix up about 6 to 8 ounces of a 10% bleach + 90% water solution to pour into the drain you cleared. This will kill any biological (mold, etc.) blockage in the tube. Empty the drain pan on the floor under the fridge again - but be extra careful as it has bleach in it.
My fridge did this to me several times before I figured out that ice was blocking my drain. I got a piece of #10 copper wire - long enough to hang from something above (coil, heater, etc.) in the coil compartment down about 4 - 6 inches into the drain tube. Doing this allows the warm air from the heated space during defrost cycles to be conducted down the copper wire into the drain tube - making it it impossible to freeze up. It works perfectly! I recommend a #12 or 10 copper wire, but aluminum works well too. I'd stay away from steel or anything that can corrode - because it will.
Jun 13, 2013 | Refrigerators
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
the thumping noise is normal
Jan 13, 2009 | Refrigerators
Water leaking
Jan 12, 2009 | Roper RT21SKXLQ Top Freezer Refrigerator
STANDING WATER ON TOP SHELF
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Plugged defrost drain line in KitchenAid Refrigerator KTRS22KHBT00
algae, bread ties andf other thing mysteriously get in there and clogg it
Jan 10, 2009 | Refrigerators
Leaking water out of the front freezer side
empty out the freezer and remove the back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water drains from freezer compartment into refridgerator
Jan 09, 2009 | Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
312 people viewed this question
Top Sub-Zero Refrigerators Experts
John Tripp
John Tripp
louis_benton
Level 1 Expert
DOUG DYKAAR
DOUG DYKAAR
Level 1 Expert
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
