Hi I have a Weathermaker ducted air con model WMHO 0487 and it is flashing HP or LO I have no manual to guide me
  • 158 Answers
This means either its got gas leak or outside unit fan not working.try off and on circuit breaker and if it shows ho or lo again then definitely there is a problem.when after resetting power see outside unit if fan is running if yes and if it stop again then it's gas leak
Posted on May 10, 2009
Overheating briggs & stratton motor model #126t02-0487-b1
what do you mean by overheating make sure all the fins in engine are clean and free of debris and also the top of flywheel is clear as well it must be to keep it running cool
Jun 04, 2013 | Garden
I have an older Jenn-Air Gas-electric grill-range Model SEG196-C and it came with a care manual but without an installation guide. Jenn-Air was not able to supply one. Anyone know how to install the...
oh my! I had seen this model long back! About 10 years i guess.. I think i have a manual somewhere will look for it and post it if i have.
Apr 16, 2008 | Kitchen Ranges
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Have lost my user manual for Fujitsu ducted air con model no AOT45LJBYL. Cannot find online please help
I just moved into an apartment with Fuji ducted air - no manual, and the control box wasn't set properly.
Perhaps this PDF manual will help you too.
http://www.fujitsugeneral.com/wired_remote_down.htm
Jan 10, 2010 | Fujitsu Heating & Cooling
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
Cleaning electronic air filter
What brand and model is the air cleaner?
Often you can find the mfg. website and download the .pdf file of the manuals.
The air cleaner will be located on the return air duct of the furnace and should have a nameplate and a model# somewhere.
Some use disposable filters and some need to be cleaned with dish detergent and can be very fragile. Hope this helps.
Matt
Jan 04, 2009 | Carrier 38CKC036 Air Conditioner
REMOTE WON'T WORK WITH AIR CON UNIT
First turn off all the power inside and out then back on and change your batteries in the remote. And look on the remote for an extra switch that may have been moved during the outage and you don't ordinarily see it. If neither of these solutions work its most likely a service call. to tell you more.
Dec 12, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Resetaear hp deskjet F2180
Pardon my rusty Spanish:
Limpa donde corre la papel con una lata de aire, en caso se quedo un pedaso adrento la imprezza.
Secundo, limpa los reduas de rubber con alachol.
Ultimo - desenchfle lo de la pade unos 5 minutos y trata otra ves.
Sep 16, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Memorex users guide
We have the manual. We just found it... Long story! Where can i post it and should I just re-write it online someplace where peeps can find it?
Jun 12, 2008 | Memorex MPH1089 Digital Answering Machine
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
