Question about Bruder Cat Skid Steer Loader
631 clark skid steer won't drive or steer the left side? the chain is still on the sprockets.
    Problem Solver:
  • 9 Answers
With all the hyd pressure released, need to unhook the 2 big hoses going to the hyd motor on the chain case on the left side and CAP OFF with fittings. Next start the machine and SLOWLEY move the travel control for the left side a little front and back, you should hear a loud growl from the hydrostat, showing that it is pumping under load. Dont do this long, but enough to test. No noise means the problem is in the hydrostat, possiably bad slipper plate, rotating group or both high pressure relief valves.If you have noise the problem is in the hyd motor. Good luck and be carefull!!!
Posted on May 19, 2009
How do I adjust creating on 1845c case skid steer
Cat® Skid Steer Loader ' Drive Chain Adjustment ... - YouTube
? 1:39
https://www.youtube.com/watch?v=FUtx88JifxY
Sep 27, 2011 - Uploaded by Cat® Products
Cat® Skid Steer Loader ' Drive Chain Adjustment & Chain Oil. Cat® Products ... Crane picking a skid steer out of a building. Unsafe - Duration: ...
How to change a drive chain on a case 90 XT - YouTube
? 2:27
https://www.youtube.com/watch?v=WBWVSpgZkKQ
Dec 27, 2014 - Uploaded by rayray haque
I made this video because I recently had to fix the drive chain on my skid steer. But there were no easily ...
Case 1845C Chain adjustment question - Heavy Equipment Forums
www.heavyequipmentforums.com/showthread.php?...Case-1845C...adju...
Mar 6, 2012 - 15 posts - ‎5 authors
I noticed it was making a popping noise in the front left wheel, so I. ... It appears that this skid steer is pretty much indestructible if taken care of ... Case 1845c Skid Steer Problem - Heavy Equipment Forums
Apr 21, 2013
Case 1845C Uneven speed while travelling
Nov 24, 2012
1845c what things go bad - Heavy Equipment Forums
Jun 9, 2009
1845C Fan belt change question - Heavy Equipment ...
Apr 9, 2009
More results from www.heavyequipmentforums.com
Dec 28, 2015 | Cars & Trucks
Tip
Drive Hub Assembly Replacement for Stairmaster 4000PT Stepper
Stairmaster Stepper Drive Hub Assembly Replacement
  1. Remove the side covers.
  2. Remove the step chain retainers.
  3. Supposrt the pedal arm. Unhook the pedal arm return spring from the spring hanger. Lift the step chain up and off the clutch sprocket and lower the pedal arm to the floor. Repeat on the other side.
  4. Remove the snap ring from the left end of the drive shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  5. Remove the drive chain.
  6. Remove the sprocket and other small parts from the left side of the hub assembly.
  7. Slide the drive shaft to the right, out of the hub assembly. If you remove the right-hand clutch sprocket form the drive shaft, do not confuse it with the left-hand clutch sprocket.
  8. Loosen and remove the two remaining bolts and nuts that hold the hub assembly to the frame. Remove the hub assembly.
  9. Inspect the drive shaft, bushings, thrust washers, and clutch sprockets for excessive wear or pitting. Replace any worn components.
  10. To reinstall the hub assembly, carefull reverse the disassembly procedures. Be sure that the right- and left-hand clutch sprockets are positioned correctly; the wide shoulder of the sprocket should be facing away from the hub on both sides.
  11. Chain Tension. The drive shaft is mounted in an eccentric hub. Rotate the hub so the marked hole is in the 12 o'clock posistion, lining up four holes in th hub with the four holes in the frame. Use this hub position when reinstalling the drive chain since the distance between the drive and the transmission shafts is at a minimum. The hub is in the proper position when the drive chain has a total of 1" to 1-1/2" of play, up and down, at the slackest point in the chain. If it is necessary to increase the tension or tighten the chain, rotate the hub counter clockwise until the chain has proper tension.
  12. Reinstall the covers.
How to Repalce the Drive Hub Assembly on Stairmaster 4000PT
on Feb 25, 2015 | Stairmaster 4000PT Stepper
Timing jeep cherockee
double posted but this time the CAM pops up.
why not read the FSM first. ? linked below.
or alldata.com . log in and read.
here ill do a paste from JUST install PART chapter.
you are doing ALL THAT book free, REALLY?
https://www.techauthority.com/en-US/Pages/Home.aspx
  1. Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner.
  2. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin.
  3. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 250 inch lbs. (28 Nm).
  4. Install right side chain tensioner arm. Install Torx®bolt. Tighten Torx®bolt to 250 inch lbs. (28 Nm). CAUTION The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
  5. Install the left side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
  6. Install left side chain tensioner arm, and Torx®bolt. Tighten Torx®bolt to 250 inch lbs. (28 Nm).
  7. Install the right side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
  8. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8429 to hold chains in place for installation.
  9. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket.
  10. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket.
  11. Lubricate idler shaft and bushings with clean engine oil. NOTE The idler sprocket must be timed to the counterbalance shaft drive gear before the idler sprocket is fully seated.
  12. Install all chains, crankshaft sprocket, and idler sprocket as an assembly . After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or equivalent. This will maintain tension on chains to aid in installation. Align the timing mark on the idler sprocket gear to the timing mark on the counterbalance shaft drive gear, then seat idler sprocket fully . Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 25 ft. lbs. (34 Nm). NOTE It will be necessary to slightly rotate camshafts for sprocket installation.
  13. Align left camshaft sprocket "L" dot to plated link on chain.
  14. Align right camshaft sprocket "R" dot to plated link on chain. CAUTION Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over torque of bolt resulting in bolt failure.
  15. Remove Special Tool 8429, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  16. Verify that all plated links are aligned with the marks on all sprockets and the "V6" marks on camshaft sprockets are at the 12 o'clock position. CAUTION Ensure the plate between the left secondary chain tensioner and block is correctly installed.
  17. Install both secondary chain tensioners. Tighten bolts to 250 inch lbs. (28 Nm). NOTE Left and right secondary chain tensioners are not common.
  18. Remove all locking pins from tensioners. CAUTION After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
  19. Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left and right . camshaft sprocket bolts to 90 ft. lbs. (122 Nm).
  20. Rotate engine two full revolutions. Verify timing marks are at the follow locations: ² primary chain idler sprocket dot is at 12 o'clock ² primary chain crankshaft sprocket dot is at 6 o'clock ² secondary chain camshaft sprockets "V6" marks are at 12 o'clock ² counter balancer shaft drive gear dot is aligned to the idler sprocket gear dot.
  21. Lubricate all three chains with engine oil.
  22. After installing all chains, it is recommended that the idler gear end play be checked. The end play must be within mm 0.004-0.010 inches (0.10-0.25). If not within specification, the idler gear must be replaced.
  23. Install timing chain cover and crankshaft damper.
  24. Install cylinder head covers. NOTE Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
  25. Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 60 ft. lbs. (81 Nm).
  26. Install the oil fill housing.
  27. Install access plug in left cylinder head.
  28. Install power steering pump.
  29. Fill cooling system.
  30. Connect negative cable to battery.
Dec 07, 2014 | Jeep Cars & Trucks
I have a Clark 743 bobcat and i have lost forward and reverse on one side it takes up in both directions but will not drive. can any one help?
it could be sheared splines , broken chain hydraulic motor failure drive sprocket loose on shaft.
Dec 06, 2014 | Cars & Trucks
New Holland L-445 Skid Loader
Find someone who knows about chain drives, a biker or a mechanic. Get it on a bench so they can get to it easily.
Dec 16, 2013 | Garden
I replaced the right side head on my 2001 mustang gt and i need to know how to set up the timming so it will run right
Hi, this engine user copper links on the chain align the copper links with the marks shown on the diagram below. Please let me know if you have more questions, and thanks for using FixYa.
To install:
  1. Compress the timing chain tensioner plunger in a soft jaw vise and install a retaining clip to hold the plunger in place.
  2. Remove the tensioner.
  3. If the copper links are not visible on the timing chains, mark one link on each end of the chain.
  4. Install the left and right timing chain guides and tighten the bolts to 89 inch lbs. (10 Nm).
  5. Position the lower end of the left timing chain on the crankshaft sprocket, aligning the copper link with the timing mark on the outer flange of the crankshaft sprocket.
  6. Position the timing chain on the left camshaft sprocket with the camshaft sprocket timing mark aligned with the copper link.
  7. Position the left timing chain tensioner arm on the dowel pin and install the timing chain tensioner. Tighten the bolts to 18 ft. lbs. (25 Nm).
  8. Remove the retaining clip from the tensioner plunger.
  9. Position the lower end of the right timing chain on the crankshaft sprocket, aligning the copper link with the timing mark on the outer flange of the crankshaft sprocket.
  10. Position the timing chain on the right camshaft sprocket with the camshaft sprocket timing mark aligned with the copper link.
  11. Position the left timing chain tensioner arm on the dowel pin and install the timing chain tensioner. Tighten the bolts to 18 ft. lbs. (25 Nm).
  12. Remove the retaining clip from the tensioner plunger.
  13. Ensure correct alignment of all timing chain links and sprocket timing marks.
  14. Install the camshaft roller followers and tighten the camshaft sprocket bolts. See the procedure under Camshaft.
  15. Install the crankshaft sensor ring on the crankshaft.
    Fig. Timing chain link and sprocket timing mark alignment-4.6L engine
  16. Apply sealant to the front cover mating surface as shown.
    Fig. Sealant application to the front cover mating surface-4.6L engine
  17. Install a new gasket on the front cover, then install the front cover and hand tighten the bolts.
  18. Tighten the front cover bolts in the sequence shown to 18 ft. lbs. (25 Nm).
  19. Tighten the front cover-to-oil pan bolts in the sequence shown to 15 ft. lbs. (20 Nm), plus an additional 60 degrees
    Fig. Front cover bolt tightening sequence-4.6L engine
    Fig. Front cover-to-oil pan bolt tightening sequence-4.6L engine
  20. Lubricate the engine front cover and oil seal lip with clean engine oil and install the seal using a seal installer.
  21. Apply sealant to the Woodruff key slot in the crankshaft pulley, then press on the crankshaft damper.
  22. Tighten the crankshaft damper as follows:
    1. Step 1: 66 ft. lbs. (90 Nm).
    2. Step 2: Loosen the bolt one full turn.
    3. Step 3: 37 ft. lbs. (50 Nm).
    4. Step 4: 90 degrees.
  23. Connect the crankshaft position sensor connector.
  24. Install the power steering pump and tighten the bolts to 18 ft. lbs. (25 Nm).
  25. Install the wiring harness retainer to the power steering stud bolt.
  26. Install the power steering pump pulley shield.
  27. Install the water pump pulley.
  28. Install the J bracket to the engine front cover stud bolt.
  29. Install both left and right camshaft position sensor connectors.
  30. Install both left and right radio interference capacitors.
  31. Connect the hoses from the coolant crossover.
  32. Install the valve covers. See the procedure under Cylinder Head.
  33. Install the right side idler pulley.
  34. Install the accessory drive belt.
  35. Install the coolant degas bottle.
  36. Connect the negative battery cable.
  37. Fill the crankcase with clean engine oil.
  38. Start the engine. Check for leaks and proper operation.
Aug 14, 2011 | Ford Mustang Cars & Trucks
I would like to have a diagram of the timing comfiguration of a 2002 dodge intrepid 2.7 .....i am very interested in the timining marks for the camshafts
Hi, this engine uses plated links in the chain to match marks on the gears. See figure and installation procedure below. Let me know if you have any questions and thanks for using FixYa.
    1. Install the timing chain by performing the following procedure:
    1. Verify that the crankshaft sprocket timing mark is aligned with the mark on the oil pump housing.
    2. Place the left side primary timing chain sprocket onto the chain, while aligning the timing mark on the sprocket to the 2 plated links on the chain.
    3. Lower the chain with the left sprocket through the left cylinder head opening.
    4. Loosely position the left camshaft sprocket over the camshaft hub.
    5. Align the plated link to the crankshaft sprocket timing mark.
    6. Position the timing chain around the water pump drive sprocket.
    7. Align the right camshaft sprocket timing mark to the plated link on the timing chain and loosely position the sprocket over the camshaft hub.
    8. Verify that all the plated links are aligned to their proper timing marks.
    1. Install the left lower timing chain guide and tensioner. Torque the bolts to 21 ft. lbs. (28 Nm).
      NOTE Inspect the timing chain guide access plug O-rings before installing. Replace damaged O-rings as necessary.
    2. Install the timing chain guide access plug to the left cylinder head and torque to 15 ft. lbs. (20 Nm).
      NOTE To reset the timing chain tensioner, oil will first need to be purged from the tensioner.
    1. Purge oil from the timing chain tensioner using the following procedure:
    1. Remove the tensioner from the tensioner housing.
    2. Place the check ball end of the tensioner into the shallow end of the Tensioner Resetting Special tool 8186.
    3. Using hand pressure, slowly depress the tensioner until oil is purged from the cylinder.
    4. Reinstall the tensioner into the tensioner housing.
    1. Reset the timing chain tensioner using the following procedure:
    1. Position the cylinder plunger into the deeper side of the Tensioner Resetting special tool 8186. Apply a downward force until the tensioner is reset.
    WARNING
    Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    1. Install the chain tensioner into the right cylinder head.
    2. At the right cylinder head, insert a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    3. Turn the left camshaft by inserting a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    4. If necessary, rotate the engine slightly clockwise to remove any slack in the timing chain.
    5. To arm the timing chain tensioner: Use a flat-bladed prytool to gently pry the tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner extends.
    6. Inspect and replace the timing chain cover gasket and oil seal.
    7. Apply a 1 / 8 in. (3mm) bead of sealer at the parting line of the oil pan and engine block.
      NOTE When installing the timing cover, guide the seal over the crankshaft to prevent damage to the seal-s lip.
    Install or connect the following:
    Timing cover and gasket and torque the M10 bolts to 40 ft. lbs. (54 Nm) and the M6 bolts to 105 inch lbs. (12 Nm)
    Accessory drive belt tensioner pulley
    Power steering pump
    Crankshaft damper
    Crankshaft center bolt and torque the bolt to 125 ft. lbs. (170 Nm) using tool 8191
    Accessory drive belts
    Fan module and electrical wiring harness
    Upper radiator crossmember
    Negative battery cable
    Dec 25, 2010 | Dodge Intrepid Cars & Trucks
    Need manual for case 1845C skid steer
    My 1994 1845c case skid steer, Drive assy won't go forwards or backwards on right side tires.Left tires will operate fine.looked into chain area fluid was up, chains okay but fluid looked milky compared to the left drive assy.Could it be the right drive pump that has gone to heaven? When I bought it 2 years ago I noticed the right side DRIVE TRAIN was not as fast as the left when going forwards too.Could you please give me an idea where to look first? Thanks Frank
    Feb 17, 2010 | Milwaukee Tool Case Heat Gun
    I have a 99 dodge intrepid that threw a rod and my father-in-law and I have been trying to time the car for a year now. We get number one piston up but the mark on the oil pump doesnt line up with the mark...
    I'm not sure what you may be "doing wrong", but here is the manufacturer procedure for aligning the timing marks.
    ^Refer to this diagram during step 12.
    ^Refer to this diagram during step 13.
    ^Refer to this diagram for step 19.
    1. Align crankshaft sprocket timing mark to the mark on oil pump housing. NOTE: Lubricate timing chain and guides with engine oil before installation.
    2. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links.
    3. Lower the primary chain with left side sprocket through the left cylinder head opening. NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
    4. Loosely position left side camshaft sprocket over camshaft hub.
    5. Align timing (plated) link to the crankshaft sprocket timing mark.
    6. Position primary chain onto water pump drive sprocket.
    7. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain and loosely position over camshaft hub.
    8. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
    9. Install left side lower chain guide and tensioner arm. Tighten attaching bolts to 28 Nm (250 in. lbs.). NOTE: Inspect oil ring on chain guide access plug before installing. Replace O-ring as necessary.
    10. Install chain guide access plug to left side cylinder head. Tighten plug to 20 Nm (15 ft. lbs.)
    11. NOTE:
    To reset the primary timing chain tensioner, engine oil will first need to be purged from the tensioner.
    12. Purge oil from timing chain tensioner using the following procedure:
    a) Place the check ball end of tensioner into the shallow end of Special Tool 8186.
    b) Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
    13. Reset timing chain tensioner using the following procedure:
    a) Position cylinder plunger into the deeper end of Special Tool 8186.
    b) Apply a downward force until tensioner is reset. NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball. CAUTION: Ensure the tensioner is properly reset. The tensioner body must bottom against the top edge of Special Tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    14. Install the reset chain tensioner into the right cylinder head.
    15. Position tensioner retaining plate and tighten bolts to 12 Nm (105 in. lbs.).
    16. Starting at the right cylinder bank, insert a 3/8" square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 in. lbs.).
    17. Turn the left side camshaft by inserting a 3/8" square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 in. lbs.).
    18. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
    19. To arm the timing chain tensioner: Use a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner is armed (extends).
    20. Install the timing chain cover, crankshaft damper, and cylinder head covers.
    21. Install camshaft position sensor and connect electrical connector.
    Hope this helps!
    Mitchell
    May 16, 2009 | 1999 Dodge Intrepid
    Bruder Cat Skid Steer Loader Logo
    1,074 people viewed this question
    Top Bruder Toys Experts
    ptpumpman
    Marc Taylor
    Colin Stickland
    Colin Stickland
    Are you a Bruder Toy Expert? Answer questions, earn points and help others
