Thermostat unit not cooling house.
I just bought a new house, and I cannot set my honeywell thermostat. If I try to make the house cooler and press the down temp arrow, it will display that the "set" temp is changing, but the unit doesn't turn on, and the current room temp doesn't change. We have the thermostat set to cool and the fan is on. Any suggestions?
  • 15 more comments
  • melaniedash May 09, 2009
    The heat has been run successfully, but not the cooling. I'm not sure about the outside unit, I'll have to check.
    I checked the outside unit, and it doesn't appear to be coming on.
  • melaniedash May 10, 2009
    All breakers are turned on. I turned off the AC breaker momentarily and back on - no effect.
    Yes, there is. There are two red lights inside, and neither is lit.
    Inside the box there is a fuse, with two red lights. They both read Line 1, Line 2 - Fuse bad when lit. There is an "ON" - on the top, and an upside-down "OFF" on the bottom.
    we set the thermostat to cool and the temp to 40 (as low as it would go) and waited approx. 30 sec. There was no clicking in that time. We tried switching it to off, then back to cool, but no results.
    When the thermostat is switched to cool, the display momentarily changes to the temp that it is set at in "cool" mode, and it will turn on the fan, but no AC. The fan turns on almost immediately after setting it to cool.
    Thank you scspriggs! You have really helped out. At least I won't feel so clueless when I call for service tomorrow. I really appreciate you taking the time to help out.
  • Samuel Charles Spriggs May 11, 2010
    This is not what I was hoping.
    Is there any indication you get from/on the thermostat that it is going into cool mode? -- Such as a click at the thermostat or some display changing? If so how long does this take after you set tstat to cool.
    I'd start by turning the tstat to "off" for a few minutes.
    Okay. It sounds like all the proper power is connected to the A/C unit.
    Next two prime suspects to me would be the A/C compressor relay and the compressor run capacitor.
    First, to investigate a bit on the relay:
    - you will need someone inside operating the thermostat
    - someone outside to listen for a clilck
    - set the thermostat to cool and set the temp very low
    - when the thermostat powers the controller (which may not be immediate) the relay outside is energized -- good or bad, the relay usually clicks when it's energized
    -- if you get clicking, that tells us the controller/tstat is probably okay
    So, run this test and let me know what you find.
    Sorry, I should have asked as well, if there is a handle on this outside box, or maybe one or two toggle switches in the front cover?
    That sounds like a promising clue, but nothing definite yet.
    Can you open the outside box and tell me how it is labeled and what any text reads if there is any?
    There should be a fuse box or a disconnect box outside on the wall near the A/C unit -- is there?
    I would check the A/C breaker in the main service panel. It's a 220 breaker (double pole), i.e., it has two "switches" on it. This may have been turnd off for the season.
    If this is not the problem, let me know. We'll go to the next step.
  • Dennis Boxerman May 11, 2010
    even though you are changing the "Set" temp., is the outside unit coming on?
    Let me know and we can continue.
    Have you successfully run this A/C system since you moved into you new home?
  • Anonymous Mar 13, 2014
    Ritetemp thermostat. Don't know how to operate it yet?
    President:
  • 1,489 Answers
Okay. Here's what I suspect in order of probability:
- low refrigerant charge
- contactor not getting 24 volts from controller (controller problem)
- bad contactor
- bad capcitor
I'd start with the charge, as suggested by mastatech. But if it is low, you'll need a service call, anyway, so pressing the needle valve may not be necessary.
I'm assuming you're not going to be taking the unit apart and testing stuff, so you'd need a service call for that as well.
I guess bottom line is, call for service. At least, I think we've ruled out simple stuff which will avoid paying for a service tech to come out and flip a switch.
Maybe mastatech has some other recommendations.
Posted on May 10, 2009
  • Samuel Charles Spriggs May 10, 2009
    You are very welcome.
    If you wouldn't mind, could you tell me what the service tech finds/does?
    thanks...
    Charlie
  • 478 Answers
Check the outdoor unit it could just be turned off at the circuit breaker if it is runninng outside and the air out of the top is cool. Either the compressor is not running or there is no charged. just press in the needle valve to see if it has a charge.
Why does it interfere with the A/C?
this all depends on the location of the thermostat that will only cool the area where it is at that tempature that you have it set on if you have a hotter room then you have to either turn it up to a higher setting cooler or make sure your ducts are open or insulate that room better it is to hot
May 26, 2015 | Honeywell Heating & Cooling
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
On my honeywell rth230b thermostat, sometimes when i try to turn on the a/c, the snowflake will just blink and the a/c will not kick on. why does it do that?
They do that sometimes as a timing feature when going from heat setting the to cool setting or vise/versa. It should not do that when the thermostat is off and then you switch it to cool. Make sure the batteries in the thermostat are fresh. And make sure the thermostat is fully seated on the housing. Also check the wires are fully inserted into the connections on the thermostat housing and the wiring is correct.
Sep 14, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Heating & Cooling Logo
334 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
