Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Doorwillnot go up or down ,lightstays on in the motor unit, one sencer works properly, the other stays green even when blocked
  • Anonymous May 20, 2009
    garagedoor open suddenly stopped working. light works but remote or wall mounted switch does not work
    President:
  • 3,197 Answers
It sounds like you have a bad drive gear. Remove the cover and you will find it just in front of the motor. Most likely stripped.
Posted on May 11, 2009
Cam shaft position sensor 350z
The Cam Shaft Position is behind the motor on passenger side and has a green cap with 2 little wires going to it .with a 10 mm bolt to take out now what most people on here did not tell is that it was hard to take the green cap off the sencer first because the clip is on the bottom so you cant see it to take it off and if you just try to take a flat head screw driver to it you will bust your green clip.so take the sencer and cap off together and then take the green cap off after you get the sencer out .ok when you take the 10mm bolt out then you can reach down and pull the sencer out but its pretty hard just to pull out your going to want to twist it but you dont have to you are just pulling against the rubber O ring thats on the sencer just pull hard and it will come out.then pull the cap off .you acually push in on the clip towards the sencer to get it off ,not down ,but towards the bolt hole ,to take off,repalce clip put new sencer on and put sensor in motor,dont wiggle around on the wires to much because they are little and I could see braking one if not both
Mar 23, 2012 | 2004 Nissan 350Z
My Goodman model GMS90703BXA has a problem wherein after a cycle, the ventilator / discharge fan doesn't shut down properly. It stays on after the burner has shut off and after the main fan has shut off. ...
Hello, usually this happens when the pressure switch remains open, this could be due to a blocked flue pipe, water inside the tube between inducer motor and pressure switch, or the switch itself is going bad. Condensation can form and leak back to the pressure switch through the tubing and causing an intermittent problem with the inducer motor running continuously
Mar 01, 2011 | Goodman GMS90703BXA Heater
Inducer motor runs then i hear 2 clicks then thats it and the motor will stop running after another minute or so
check air filter is clean , clean flame sencer , see if ignition coil is glowing or cracked , check connections to psb from flame sencer is tight see it tube from fan is not blocked or connection is not blocked, and at pressure switch , jump out pressure switch see if it lights ,
Feb 05, 2011 | Goodman GMS90703BXA Heater
I have a 1998 chevy suburban that I bought. The motor was bad (through the number 5 piston) I put a nother motor in it but the block that I put in was a older block four bolt I put a steel crank in it and...
you cant use the cam gears on your "new motor' the cam gear from the old one must be used if it will fit.the starter problem could be a bad solonoid or a wireing problem cant tell by your desciption.
Jul 17, 2010 | 1998 Chevrolet Suburban
2001 Montero sport runs hot on the hiway, cools when I slow down
try replaceing your temp sencer. some time they are near the goose neck or on the block ok . and see if your fan sencer is working. good luck
Apr 14, 2009 | 2000 Mitsubishi Montero Sport
Acer Aspire T180 turns green and blocks.....
TRY BOOTING FROM A SYSTEM DISK , IF THIS DOESN'T WORK YOUR RAM MAY NEED TO BE CHECK TO SEE IF ITS FUNCTIONING PROPERLY
Jul 31, 2008 | Acer Aspire™ T180 PC Desktop
2001 Ford coachman motor home
their is a speed sencer on trans might try that first if dont fix problem possible cluster problem
Jul 27, 2008 | 2001 Ford Windstar
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
157 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
