Question about Acer Aspire 5500 5570-2609 Laptop
Web cam not recognised
Pc tells me that web cam can not be found or is not working properly, I have tried to access software to repair but the system tells me that I can not, The feature you are trying to use is on a network resource that is unavailable. please help Pete
I need to turn my webcam on so i can chat with friends on facebook not sure how to do this.
Your web cam should have came with a user's manual and software to install on your computer in order for you web cam to work properly. Refer to you manual and install any software needed. The software will tell you how to operate the web cam and the user's manual will also along with troubleshooting tips.
Jan 12, 2011 | Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
In Yahoo Messenger I cant use my webcam
first you properly install the Web Cam Software, then you open the Yahoo messenger and again access the web cam. I hope it will work fine. sometimes yahoo messenger not access to Web Cam, that time yahoo messanger not working properly.
thanks
Aug 14, 2009 | HP Pavilion dv6000z Notebook
Web cam not being recognised
yes! you can go to there site and download the drivers from there.this should fix your problem.let me know if this helps or you need more help
Mar 24, 2009 | Ezonics EZCam Webcam
Unable to install webcam
I have web cam, but no cd to install in system....tell me a right solution
Jun 25, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Web cam problem
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Mar 11, 2008 | Acer Aspire 5630 Notebook
Acer orbi cam not working
Thanks
Mar 07, 2008 | Acer TravelMate 3260-4874 Notebook
How can i instal my web cam?
install the drivers cd or download the related drivers thro internet ....
Nov 30, 2007 | GE EasyCam Webcam
Logitech QuickCam STX vista compatibility?
when you were installing the software did a taskbar pop up appear and tell you that hardware was found, and then proceeded to install the cam and inform you that the Logitech STX is now installed and ready for use? If not then the cam may need to be tried in another usb port as of yet it has not been recognised by windows. Also if this is being used on a laptop, sometimes there is not enough power amps being sent be the usb port to recognise, again trying a different port may solve that. If all else fails re install the software again, but make sure windows is allowing the cam to work, as sometimes there is an updater programme that works in conjunction with the cam to update drivers etc, this will probably be being dissalowed by either windows or your internet security programme and any part of the software that is being blocked may be stopping your cam also.
Jun 11, 2007 | Logitech QuickCam Communicate STX Personal...
Creative PC-CAM software
you might have a malfunctioning camera try it on a friends computer with the software if it dosent work it probably wont work you can take it to a repair shop, if it does work your computer probably has a virus or corrupt system files all you need to do then is scan for viruses and then insert a system repair disk for your current operating system or put your operating system disk in and repaair your system.
Sep 12, 2005 | Creative Labs PC-Cam 900 Digital Camera
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
