Question about Garden
Have a Sears Craftsman lawn tractor 917.271530. It will not charge the battery. Need some information on replacing the alternator. I have the owner's manual, and see the exploded views, but there is not much detail on the alternator, and I see there is also a wire-connector/alternator. I think I need some advice.
Need Ground belt installation step by step
Posted on Jul 14, 2010
  • 246 Answers
Hello
I Sent an Answer but am Unsure if it was Posted or Not. Here is a Possible Repeat Answer.
>>The Following is the Instruction File I Made for Removing the Flywheel from Most Mower Engines for Replacing the Flywheel Key, the Stator/Charging Coil/Magneto and the Point Set on Older Engines without Electronic Ign Coils.
>>It is the Basics and if you have a Question, Please Ask. Any Input to Make this File Better is Appreciated.
>>***Disconnect the Coil Wire from the Spark Plug. Remove the Blower Housing (metal engine cover).
>>Remove the Coil.
>>Remove the Flywheel Nut or Starter Cup (Depends on the Model).
>>Now Attach a Steering Wheel Puller to the Flywheel Using the Threaded Holes in the Flywheel.
>>Tighten the Puller.
>>Now Hit the Puller with a Hammer. Repeat this Procedure Until the Flywheel Pops Up or can be Lifted Off the Crankshaft.
>>On Some Models you Can Not Use a Puller and and the Jaws of a Standard Puller will Not Fit. On these Type Engines you can Use a Pry Bar and a Pipe Cap that is Slightly Larger than the Crankshaft. Place the Pipe Cap Over the Crankshaft to Protect it. Place the Pry Bar Under the Thick Section of the Flywheel and Pull Up Against the Flywheel.
>>**BE CAREFUL DO NOT PUT A HOLE IN THE BLOCK UNDER THE FLYWHEEL** >>Now Hit the Pipe Cap that is on the Crankshaft (covered with the Pipe Cap). Repeat the Procedure Until the Flywheel can be Lifted Off the Crankshaft.
>>*** Be Sure you have the Flywheel Torqued to the Proper Torque (I require the Model and Spec/Type Numbers Off the Engine to Provide the Proper Torque) and Set the Coil Gap to .020in..***
The Stator/Charging Coils are then Unbolted and Removed and the New Stator/Charging Coil is Attached.
Assemble the Engine in Reverse Order.
The Flywheel Nut Torque for you Engine can be Located at this Site Addy; http://outdoorpowerinfo.com/engine_specs/ .
The Clearance for the Coil and Flywheel was Included Earlier in this E-Mail.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Replaced battery and will not make a sound. old battery started to smoke and tractor just quit. what could have happened
Charging control system has failed and is overcharging the battery. Probably the alternator diode, not sure if it's a replacement part on this model, you may need to replace the complete unit.
Nov 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need a wiring diagram for sears model 917.272066 riding lawn mower
Should contact SearsPartsDirect.com,they have all the wirings on all their Craftsman lawn tractors. There is another way you might find a wiring diagram. Look in back of your Owner's Manual,i have found a wiring diagram & part numbers to include,the whole tractor is broken down in a diagram format. There are other lawn mower shop that should have a wiring diagram,i.e. AMCParts.com. Hope this helps.Sincerely,Brad Locke DTD 12/04/15
Oct 27, 2012 | Sears Garden
I need replacement blades for a Craftsman LT1000
get part # or model# from owners manual and go to sears.com and order or stop into a local sears with the numbers and theyll set you up!
Sep 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 24 kohler engine
there is no alternator on small engines it is called a stater which is usually on the coil all one unit with coil but does the battery charge on a battery charger the battery might be bad & wont take a charge let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The cable broke which engages my blades on my craftsman 17 .5 hp 42 inch. I need a model part number for the same . I have lost my owners manual with that information
locate mod # on tractor may be under seat
go to sears.com click on parts direct and enter that number and it will take you to the parts section for that mower.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need the owners manual for this lawn mower Craftsman 917.377220 6.75 HP
Here a website that gives a list of Craftman Lawn Mowers and it owner manuals. Hope it help, its were I found my manual.
http://www.craftsmanlawn.com/Walk-Behind-Mowers/
May 02, 2009 | Garden
Garden Logo
1,112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
