Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Won't engage blades to cut lawn
Sears 17.5 42 inch sit down tractor. When I pull up lever the blades do not engage to cut the grass. It was working stopped during the process of cutting the lawn. It looks like wire is loose or snapped off. Can that be corrected easily or do I need to call for service
  • 86 Answers
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
Posted on May 10, 2009
My ride on lawn mower is cutting out every time i try to engage the cutting blades
Sometimes it is due to the ETHANOL fuel you are using. ETHANOL is attracting moisture and after a while it builds up water in the tank.
Jul 06, 2015 | Garden
I have a Sears 22 inch lawn mower, model #917.376070, Serial number 121906M-029886. I recently purchased and installed a new blade from the Sears parts store in Milwaukee (part no. 917-141114) and...
The blade only cuts on the outer 4 inches of the blade rotation(diameter). As the mower moves forward, it cuts the full width of the deck. If sprigs of grass are missed or excessive vibration is present, you may have a bent crankshaft. Check and be careful, ejection of the blade hazard exist.
Jul 17, 2017 | Computers & Internet
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do u get the blade going to cut grass
there should be a lever or switch that will make
blades turn..
Jul 02, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Apr 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman GT5000: Dies when switch is pulled to engage blades
Hi
Check for burnt fuse behind dash. If no burnt fuses check if getting power to magnetic clutch mounted on bottom of engine crankshaft. Make sure wires are not broken by magnetic clutch. Make sure the safety seat switch is working. Make sure you are sitting on the seat when you try to engage the blades. If that does not work try pushing and wiggling the seat sensor. Check make sure wire is attached to safety switch under seat.
Apr 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,026 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
