Installing new power supply in hp pavillion a705w
Need to know , which connectors plug into where.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
You will see one big connector with 20 pins which goes to your motherboard and fits from only one direction. connect the 4 pins connectors to your CD/DVD rom(s) and hard disk(s). again the connector can be plugged from one side. If you have a floppy drive then you can connect the smaller white 4 pins connector to it.
Good luck
don't forget to rate this solution. if your problem is solved please rate it as solved
Thank you
Posted on Oct 12, 2007
SOURCE:
Integrated 10/100 Network Card for HP Pavillion a705w: My brother-n-law HP Pavillion a705w is dropping it's internet connection after about 2 minutes. We thought it was the Cable Modem Box (Motorola)......
Hello my name is Israel. On your type of cpu your network card is integrated into th emother board. YOu can purchase one and just connect it inot one of the slots. the instructions as well as the software should be included in the package. It will be a very painless installation. You can probably get a dlink network card at Best Buy for about $15. Good Luck.
Feb 15, 2011 | HP Pavilion a705w PC Desktop
I HAVE A HP A705W COMPUTER AND I NEED TO KNOW WHAT INTERFACE IT IS BEFORE I BUY A DVD BURNER. IS IT A SATA OR IDE
Has it got an IDE cable feeding the hard drive, (Wide 40 pin connector) or has it got a narrow SATA cable (4 pin) with a power lead). That is how to tell.
They are very different.
Jan 27, 2011 | HP Pavilion a705w PC Desktop
What memory do I need to upgrade my hp pavillion a705w
hello
for that particular HP computer, you need this memory module
256MB, PC2700 DDR-SDRAM DIMM memory (32Mx64, DB221AX)
ask for P/N DD234-69001, SHOULD BE ABOUT $20-$25 PER STICK
hope this helps
Nov 09, 2010 | HP Pavilion a705w PC Desktop
The computer isn't coming on the power cable is plugged in the green light is blinking but nothing else is happening
Do you hear fan starting noise? If you dont hear any noise most probably you need new power supply.
you can buy cheap power supply from www.aria.co.uk
if you hear the fan noise!
Does you motherboard starting with POST (a beep noise).
if you dont hear. well you need a new motherboard which should be compatible with your other peripherals.
if you hear a beep noise! Most probably your operating system is corrupted. (Boot file corrupted)
in this case you may have to install new operating system.
Thank you
if you got any problem let me know
[email protected]
Sep 03, 2010 | HP Pavilion a705w PC Desktop
Connect projector to HP desktop
If you are attempting to connect an LCD projector to a laptop,you connect a monitor cable to your video card and the other end to the monitor input connector. You may have to use an adapter, I know on my LCD projector I had to use a DVI to VGA connector.
Can't say much more not knowing if you are having a problem with a particular brand of projector
Sep 21, 2009 | HP Pavilion a705w PC Desktop
I have an hp a705w it wont turn on the light blinks
The Power Supply Might Have Gone Bad, or the motherboard could have loose connectors on it/be worn out. If It Is Still Under Warranty Have It Diagnosed. Does It Beep At All?
Aug 20, 2009 | HP Computers & Internet
Hello I have a hp pavillion a705w it wont turn on any monitors
How Would I Go About Hooking 2 Monitors Up To My a705w
Jan 18, 2009 | HP Pavilion a705w PC Desktop
Computers & Internet Logo
457 people viewed this question
Ekse
Alun Cox
