Paper jam with kodak esp 7 cannot get paper out
  • 1,218 Answers
Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer. get more information and help from here.
Posted on Sep 01, 2010
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Jan 12, 2011 | Kodak Office Equipment & Supplies
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Psper jam in Kodak ESP all in one printer
try using the website www.kodak.com/go/itg
If still get the same paper jam error contact Kodak tech support.
Printer will be replaced if on the spot if bought from walmart for other stores you'll be asked to fax or email the proof of purchase.
Jan 23, 2010 | Kodak ESP 5 Printer
Kodak esp 7 paper jam
you will get a new only if the printer is within 30 days from the date of purchase so it is ok to have refurbished printer,,,,,,,just give them a headache when you have problem with this..........
Jun 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Esp 7....Claims to have a paper jam..can not find any paper in machine ..I have unplugged ..still has the same error
Go to www.kodak.com/go/itg and follow online instructions on how to solve the issue. if the issue is not fixed,Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost..
Apr 14, 2009 | Kodak ESP 5 Printer
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Mar 19, 2009 | Kodak ESP 5 Printer
386 people viewed this question
jasbo
jasbo
