Question about Blodgett DFG-100 Gas Single Oven
Hello are you there
  • 1,006 Answers
Do you need sumthing?Driver software help????
Posted on Oct 12, 2007
My oven is comimg up with the F4 fault message?
Hello Rose,
The error code F4 are code that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
The F4 error code is for sensor that has a open circuit,so instead of the 1060-1100 of a good it the display on the meter will show infinate resistiance ( the meter display will not change)
If at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
GENE
Oct 19, 2011 | Ovens
Hello! I have a Thermador double oven and it is beeping F-7 as it is finishing up a self-cleaning. In addition I am also getting F-1 F-1. The bottom oven cleaned and unlocked with no problems. Now the...
Hello, Per my manual:
F7 - This is caused by close contact to the control panel for more then 32 seconds,such as someone leaning against the controls or objects hanging in front of controls.
F-1 - Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn it back on. If condition persists, note the code number and call an authorized servicer.
Hope this helps,
Vicki
Oct 15, 2010 | Thermador SC272T Electric Double Oven
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Hello, I have a Soutbend cooker serial N° NX
Call Rick at Restaurant Parts and More. 1-888-814-1110
Be sure to have model and serial numbers to ensure the correct part.
Nov 18, 2009 | Southbend S560DD (Gas) Oven
Hello chaps my new world e60cm oven is only
Hi Andy. I have the same problem with mine, just had a repair man come out and the bottom heating element had gone. Don't know if this is a common fault, but maybe the first place to look.
Nov 02, 2009 | New World E60Cm Electric Single Oven
Hello, My Jenn Air oven overheats. When I set
The temp probe resistance should read between 1050 and 1150 ohms. If not. Replace it.It causes the overheating situation you describe.
Jul 16, 2009 | Jenn-Air Ovens
Supressor, transient
Hello hward,
Welcome,
You said, Hello from Baton Rouge, La. just recently nailed by Hurricane Gustav.......
during the hype of the storm, I think my wife's double oven took a electric surge and started smoking. I visually inspected the damage and saw a badly burnt and scarred flat saucer looking component (suppressor, transient)...I have ordered a replacement part and would like to know if you think that replacing this item will be all I will need to do..
If the range was under water I do not think this will be the only problem.
I believe it will cause you endless problems if it got submerged!
you may end up replacing this water logged unit!
Huuum
Thank You ,Please remember to leave a rating
Sep 07, 2008 | Whirlpool RBD305PD Electric Double Oven
Blodgett DFG-100 Gas Single Oven Logo
60 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Steve Allison
Steve Allison
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
