Question about Technics SL-1210 Turntable
Lame rca rca is only producing sound from one side(with a jiggle it makes a bad earth sound on the "missing" side)bvvvvvvvvvvvvvvvvvvvvv
  • Hopkirk
    Hopkirk Oct 19, 2007
    Thanks madskillz, I appreciate your diagnosis.
  • richard vreede
    richard vreede Aug 16, 2014
    Nonsense , it's way more easy then the metre rca cable with a technics and sound on one side??? Just left right and connect earth to the earth to one of the rca connection, but buy good ones 60euro/two)which don't connect to the metal in the middle. I still wonder what he mens by sound at one side. :)
    Problem Solver:
  • 7 Answers
You have a bad rca that tends to happen after time ... your gonna have to open up that table and un soder the old rca and replace with a new one. also check your ground cable
Posted on Oct 19, 2007
SOURCE:
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
My RCA Scenium HDLP50W151 TV makes is making a loud whining sound that varies in degree. I have picture and sound but the noise is beginning to drown out the TV volume
All projection TVs for RCA are DLP TVs, with that in mind these TVs have a lamp inside that produces white light. The color wheel is the one in charge of giving color to that light. Regularly the color wheel last between 2 to 5 years depending on the daily tv use. Most of the time when the central barring of the wheel is loose, unstable, or out of place it will cause the edge of the wheel to make contact with the housing, producing that whining, whirling, screeching or hissing sound. These sounds can either produce just a annoying sound when watching tv or can cause the tv to shut off. When this happens you’ll have to replace it, if you want to know where to buy, you can look in ebay, there are many parts you can get at very good bargains, the only thing is that you buy at a high risk of the part not working ( I had a bad experience). The other option is to buy at an electronics store online dedicated at selling tv parts, some can help you trouble shoot your problem and others may have tech support over the phone (personal recommendation: Discount-Merchant.com ). And last remember to search your part by part number, NOT by model number, two TVs with same model numbers but assembled on different dates ( different generation TVs ) will have none compatible tv parts inside, so be very carful.
Dec 24, 2009 | RCA Televison & Video
When i turn my radio on my sub makes sounds and backfeeds even when the engine is off. i tried switching the remote wire from my radio to different wires but it either doesn't work or still makes the...
Hi It will be an earth problem or even if your speaker wires or rca leads are running along side any power wires from your car, Find the most chunky metal part of your dash, clear all paint away, make the earth wire from your head unit less than 1 foot from you head unit and make sure its not conected to any earth that run back to your cars power system. if it still makes the noise make sure your speaker wires or rca leads are not running along the cars power wire they will pick up feed from them. make sure your head unit is not earthed to your cars arial silly as it sounds the arial plug in is one of your main earths to your cars audio system. hope you work it out
May 06, 2009 | Car Audio & Video
Sound car amplifier
this could be couple of reasons
no.1
check that you havent run the rca's down same side as power lead as this causes a whining sound
no.2
Check your earthing point make sure its suitable
no.3
Check your auternator maybe faulty
there is a easy solution to this and thats to by a rca ground loop isolator which filters out unwanted noises
heres one i found on ebay for £5 click here
Apr 23, 2009 | Car Audio & Video
I have a ripspeed dv720 and it produces no sound but everything else works fine does anybody know why
hi bud look for your remote lead or power antenna lead and connect the p-control lead from the head unit.thats what i did away it went awsome sound.
Apr 18, 2009 | RCA Car Audio & Video
My sub is making a humming sound
Hey austinpippen,
The noise you are experiencing is due to your rca plug shorting out causing a loop, in outher words, bad earth.
Try getting a noise filter, you take your rca plug and plug it into the noise filter, then wire it to the amp!
you can try a ground loop isolator or relocating your ground [earth].
I hope this helps you out.
Fingers crossed.
Apr 08, 2009 | Jensen A600HLX Car Audio Amplifier
No Sound out of Left side
is it possible to swap the left and right wires on the needle cartridge? does the sound change sides? if yes bad cartridge if you still only get sound from right side try changing around the rca phono plugs
Jan 04, 2008 | Technics SL-BD22 Turntable
Tv will not power on
1)Please verify service # from back of set...Very important..
2)Probable bad ground solder connections...tuner circuit
3)probable bad flyback transformer and / or horiz o/p xistor
...............T.
Dec 21, 2007 | RCA F31672ET TV
My rca lead is only working on one side(just as I had planned to bash out a demo,how frustrating!)
Oct 11, 2007 | Technics SL-1210 Turntable
Help
Check the earthing of the amp is adequate. It sounds like the amp is floating without an earth until you earth the rca outer.
Apr 11, 2007 | Jl Audio 250/1 Car Audio Amplifier
Technics SL-1210 Turntable Logo
155 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
