Question about KitchenAid KEBC107 Electric Single Oven
I hit the self clean button on my Kitchen aid oven and now the door is locked and the oven lights are off
    Problem Solver:
  • 3 Answers
I have heard that with this model, the self clean will ruin the electircal components. It sounds like you may need to have someone test it out to find what is ruined. If I were to guess I would say its the controller board. Mine was on backorder for 2 months.
There is a person in this link that has the same issue:
http://www.consumeraffairs.com/homeowners/kit_stoves.html
Posted on May 14, 2009
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Door won't open after self cleaning and cool down has stopped.
    if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
    Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    The lock on self cleaning oven door will not release
    Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
    Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Door locked after shutting down cleaning cycle earlier than
    The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
    Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
    If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
    May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidare Self Clean Oven
    I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
    1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
    2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
    3. PRESS THE "COOK TIME" BUTTON
    4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
    5. PRESS "START" BUTTON
    6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
    7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
    Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven Lock stuck open before start of self-cleaning cycle
    push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
    Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    How do I clean my frigidaire self clean gas oven
    after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
    Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
    Self Clean does not work
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
    KitchenAid KEBC107 Electric Single Oven Logo
    243 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
