Question about Toro Lawn Mower With Toro Power Tools
My toro mower will start but dies shortly there after the model# is 200016 serial # 230000001
  • 246 Answers
Hello:
Soak and Clean the Carburetor.
You can View a Breakdown at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
Need wiring diagram for a Toro Riding Mower Model 74413,serial no. 250000194
go to toro web site enter model # and should be able to get diagram,if not go to mower repair web sites they should be able to provide diagrams.
Jun 11, 2015 | Toro Garden
Part number for drive belt for toro 200016
91-2258 but your model # is a 20016 and you also have a serial number break. with any TORO product you need the serial number as well. Also, partstree.com can help you next time
Aug 18, 2014 | Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Model 200013 drive axel moves to the right to far, causing axel to destroy inside of drive wheel. what causes this condition??
There are e clips that hold the transmission in place. They go in a specific order to make it work correctly. I have included a link that will show the correct placement for the e clips and spacer rings. I might mention that this is an hour long job when you know how to do it. So be ready for it to be time consuming. Alternately you can take it to a Toro repair shop. The second link is to a dealer finder, to show you where the closest dealer is to your. I hope this helps. http://www.partstree.com/parts/?lc=toro_consumer&mn=20013%2C+22%22+Recycler+Lawnmower%2C+2003+%28SN+230000001-230999999%29&dn=3350_221-369176-0006
http://www.toro.com/locator/index.html You will need to click on the link that says homeowner.
Apr 06, 2011 | Toro Power Lawn Mower
I have a Toro Super Recycler Mdl 20033 ser 230000001 and up. Lawn mower will not start, there is no spark. New spark plug and fuel line. Change the magneto? Is this simple?
You may not need to change the ignition module. The "air-gap" on it may just need to be adjusted. That is, the distance between the pickup legs of the ignition module and the magnets integrated into the flywheel. You would have to remove the exterior cover and any sheet metal cowling (directs air flow off the flywheel around the engines cylinder). Then, the coil and flywheel should be visible. I use a standard business card as a gauge. Slide it between the coil legs and the magnet area of the flywheel. You should feel just a slight little rub. If it won't slide or the gap is large, no spark will be produced. You will have to loosen the screws holding the coil in place, double up the card. let the magnets pull the legs in against the card with magnets behind and retighten. Then recheck for spark. Post back if needed.
Apr 04, 2011 | Toro Power Lawn Mower
RE: 42'' zero turn Toro with Kohler 19 hp. Ever since I bought it new, it has used oil, I am very dissatisfied with it. Model 74360 Serial #270000001. The starter relay doesn't work correctly. It will not...
Toro is a great brand, but the Home depot models are for home use. IF it won't start correctly you should troubleshoot the problem as this is a built in safey system for your benefit. There is a switch on both parking breaks, A switch to detect you sitting in the seat. The PTO must be disengaged. Check each of these. If you have your manual you can view the schematic diagram, and test each switch. If not, you can download a manual from Toro web site. According to your model and serial number your deck would only have two blades. They also have what they call "blade stiffeners" . Your results from buying power equipment from a big box store is typical. If you need service, pay a little more, and buy from your local power equipment distributor.
Jul 12, 2010 | Toro Garden
My mower starts when cold and runs for a while OK
it sounds like the ignition coil is shorting out inside once it gets hot. or it could be the spark plug as well.
May 01, 2010 | Toro Lawn Mower With Toro Power Tools
Need the engine model number for toro mower model 2006,serial 270001124
I too was looking for the engine model number and serial number for my Toro mower to submit a claim for a class action suit. I could only find the "Mower" model and serial number. I found a guide to locate the engine information in the "Engine Service Manual" for my mower.To get the "Engine Service Manual", I went to Toro's website https://lookup3.toro.com/request/request.cfm and entered the "Mower" Model # and Serial Number. That brought me to a speific page for my mower with several manuals listed, including he "Engine Service Manual" which could be downloaded for free. The information for locating the Engine Model and Serial Number was found on the first page of the Preface. Here is a sample link for my mower Engine Manual https://lookup3.toro.com/request/filechek.cfm?Lang=EN&PubNum=492-4202&PubID=6924&Cust=anonymous_user&xCaller=Toro&PubType=9
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Toro electric start won't start manually
If it doesnt start manually,you have another issue to deal with. Whether it has electric start or not you should be able to manually pull start it. You can also get the model and serial number off the engine and contact your nearest toro dealer to have charger and key ordered. As far as a push button,it can be done,just a matter of finding someone to install one for you.
Jun 03, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
396 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
