Question about Abit AN7 Motherboard
Abit AN7 motherboard does not boot - POST code AF
I was installing a new hard disk in a friend's Abit AN7 motherboard, and all was going well until I had almost finished. Suddenly it would not boot, and gave an undocumented POST code of AF. I tried the usual reset CMOS/unplug power to motherboard/remove motherboard button cell - all to no avail. I have switched graphics card, motherboard and CPU, disk drive, and still nothing changes - still AF! The only constants were the case, CD drive, FDD, PSU and 256k memory.
What's happening? What should I do - apart from simply buying another/more recent cheap Pentium 4 system unit?
  • John Bevan May 10, 2009
    I tried this, twice, in another memory slot.  Maybe I've damaged the memory card, so I'll look for another, insert it, and disconnect everything I do not need for a re-boot (FDD, CD drive, ..).
    Are you pretty sure that POST=AF means a memory problem?
  • 32 Answers
I think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
Posted on May 09, 2009
Testimonial: "Thanks. And I sold the replacement motherboard that I did not need to buy!"
    Problem Solver:
  • 17 Answers
I think is a bios problem, a ram failiure would be C1 post code.If the bios is corrupted, try a blind bios update or if it doesn't want to, you must do a hot flash update.For more details google search for award bios hot flash.Or dump it and buy a new one.Usually when the post doesn't change at all or if it stops to 90 is a bios problem.I had a similar problem, mine hang at 90-after a complete check of uguru.In your case might also be the uguru chip.I hot flashed the bios.I used an abit nf7s 2.0 to start and then put in my bios.It worked and i also made a backup.Your chip is Winbond-4 mb capacity.
Posted on Jul 11, 2009
Good suggestions people. Memory stick fault... removed one, puter worked fine
last time it did this, memory stick AND bios issue from failed power supply
Posted on Nov 26, 2010
How to acsess the boot device menu at post on abit il8 motherboard
.Abit did not add the BIOS post to the manual.
Watch the BIOS post, most all motherboards have the hot-key menu at BIOS post.
If for some reason the hot-key is not reported on BIOS post, then you hit the DELETE key and enter the BIOS, Advanced BIOS Features Setup Menu and set what hardware you want to boot first, under Hard Disk Boot Priority, set First Boot Device
Mar 31, 2013 | Abit IL8 Motherboard
I have an Abit AN7 mobo, with a post code 9F.
hi Aaron -- i highly recommend (if you dont have it) to downloa the manual first. There are POST codes listed .
an7-top-500.jpg NVIDIA nForce2 Based AMD K7 Mainboard
FSB400, Dual DDR400, SATA RAID, IEEE1394
ABIT ?Guru Technology
for the AN7
for the manual, go to this link to download
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AN7&pSOCKET_TYPE=SocketA
do the following
on page e1 of the manula it says to clear the CMOS before installing a new mainboard..
if you feel there is sufficient thermal paste on the ehats sinbk, then leave it as it is.
first shut down the system, Remove the heatsink from CPU, carefully. Buy some thermal paste, Nexus TMP-1000 silver. Apply to the heatsink . Place it back.
Now, remove the RAM. Go to the CMOS settings via jumper, and reset -- you will notice two pins near the motherboard battery. You have to check those settings. Once done place the RAM back. The board should boot ok.
please rate my service
Nov 19, 2010 | Computers & Internet
Locks during xp install, wont go past "inspecting hardware cnfg"
Try resetting your Bios to factor default and see if you get further.
Sep 03, 2009 | Abit AN7 Motherboard
ABIT AN7 MAINBOARD HANGS @ POST CODE 90
I had the same problem, the bios is corrupted, try a blind bios update or if it doesn't want to, you must do a hot flash update.For more details google search for award bios hot flash.Or dump it and buy a new one.A hot flash worked for me for this mb and an Epox 8rda+,i also have backup bios chips now.Your chip is a Winbond,4 mb capacity.
Hope this helps, SSVik
Mar 23, 2009 | Abit AN7 Motherboard
Abit an7 motherboard front panel wiring diagram needed :)
Front pannel audio is located left of the pci slots
: : : . : : :   thats what it looks like         from left to right there are seven sets of pins 1234567.
3 and 7 should be the pins you want for a standard front panel audio as far as i see in the manual ICEBOX
Mar 22, 2009 | Abit AN7 Motherboard
Abit th7raid motherboard-160GB HD cannot recognize-needs flashing-out of my depth!
Hi coonster,
Abit TH7 Raid driver.
Windows inability to see all of your hard disk drive is not a motherboard issue.
It’s a windows issue. ( I suggest you use the hard disk drive software from the manufacture’s web site). Most allow you to download software that allows you to create a bootable floppy disk. Boot to this disk & setup the drive in a dos like window.
Once completed you can now boot to the windows CD. Do not allow windows to format
the drive.
That is what the manufactures disk will do for you. Install windows & please update it fully. Windows should see all of the 160GB after updating.
If you feel you need to update the bios, feel free to do so.
Follow Abit’s instructions on how to update the bios from this link;
http://fae.abit.com.tw/eng/download/bios/index_old.htm#486
If you have never downloaded a bios file or drivers from this site it can be a bit confusing. You’ll need to high-light the entire link below, than right click once to open the pop-up window. Than left click copy. Open internet explorer. Right click once in the address window & left click past. Than press the enter key on your keyboard. The site has a timer on the left side of the page. You’ll have to wait for it to reach zero.
Than a yellow bar will open across the top of the page that says, (To help protect your security, Internet Explorer blocked this site from downloading files to your computer. Click here for options...). Right click once on the yellow bar & left click download file. Create a folder on your desktop & name the folder " Drivers". Download the file named " infinst_enu.zip" into the driver folder. Us any uncompressing program & uncompress the file keeping the files within the driver folder. The action of uncompressing the *.zip file will create another folder named " Disk1".
http://www.nodevice.com/driver/download.html
To download the Abit TH7 Raid bios is done like the instructions above. For this bios file you’ll need to do the same with the link below;
Abit TH7 Raid bios file name " th736.exe ".
http://www.updrivers.com/getbios/Motherboard/Abit/TH7-Raid-BIOS/6187.html
Please retype verification code: "enter code listed on site".
Press enter.
Again create a folder on your desktop & name it Abit bios.
You will not find any drivers, bios or manuals directly from Abit. They no longer support this motherboard.
Mike
Nov 07, 2008 | Abit KT7A-RAID Motherboard
A17 wont boot
ok what board is it
#then check the manual for error post code error af
if not try another card liek a pci one
or agp one
Jun 06, 2008 | Abit AI7 Motherboard
Abit AN7 Motherboard Logo
1,885 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
